alignment help needed--tightening bolts moves the trunnion
Forum topic by jp90 posted 12-15-2013 05:30 PM 985 views 0 times favorited 6 replies Add to Favorites Watch
View jp90's profile
jp90
23 posts in 1734 days
12-15-2013 05:30 PM
I’m trying to align my PM 64A. Using the PALS system, I can get it aligned pretty easily. BUT, when I tighten the trunnion bolts then recheck alignment, it seems to have moved quite a bit. I’ve done it a few times, but maybe I’m doing something wrong. I have one front bolt loosened, and the two rear loose for PALS adjustment. I’ve tried slowly tightening the rear bolts at the same time, but it still moves.
Any tips?
THANKS.
View Tedstor's profile
Tedstor
1643 posts in 2628 days
#1 posted 12-15-2013 05:41 PM
How loose are the trunion bolts? I left mine pretty snug, loosening them ‘just’ enough to make the adjustements.
View jp90's profile
jp90
#2 posted 12-15-2013 05:44 PM
i guess the rear ones are pretty loose. the “loose” one in the front is still pretty tight though
View jp90's profile
jp90
#3 posted 12-15-2013 06:52 PM
In getting the table aligned, I’m near the limit of the PALS in one direction, so maybe I’m pushing the trunnion too far—-then the trunnion is sucked back when I tighten, if that makes sense.
I thought about loosening the front trunnions to start from scratch, hopefully getting the front closer. What I don’t understand is: how can the front trunnions move with the fixed length angle adjusting rod connected?
View skipj's profile
skipj
97 posts in 2267 days
#4 posted 12-16-2013 04:42 PM
Try this. Do as you are doing but take the belt off the motor first.
View jp90's profile
jp90
#5 posted 12-16-2013 04:48 PM
I actually got it late last night and forgot to post. I took the motor off entirely, which made it easier to access and move, but didn’t solve my problem. Finally I loosened the post the cranks the angle adjustment, and that did it. I was able to move the front trunnions more towards center, then adjust from the rear with the PALS.
Thanks for the replies.
skipj
#6 posted 12-16-2013 05:12 PM
Glad you got it. That’s how I had to do it on my 64A.
