Looking for large roundover Shaper Cutter
Forum topic by DangerDoug posted 12-15-2013 03:19 PM 915 views 0 times favorited 4 replies Add to Favorites Watch
View DangerDoug's profile
DangerDoug
83 posts in 1885 days
12-15-2013 03:19 PM
Found this on the inter-web.
http://toolsandmore.us/roman-carbide-dc2214-shaper-cutters.aspx
This would work if it was Left to Right feed, and might just work with it if there are not any other options [ this large at this low price].
Will not be running 100s of feet, really just want the bell shape profile for small projects.
Any thoughts?
View cabmaker's profile
cabmaker
1744 posts in 3047 days
#1 posted 12-15-2013 03:30 PM
That cutter will run either direction. (Dependent on dia. Capabilities of machine) face up or face down. enjoy!
DangerDoug
#2 posted 12-15-2013 03:36 PM
Yes thanks….If I run “face-up” I’ll have to put the work down first, then slip cutter over.
Working thru 1-3/4 hole for the reverse bell shape.
That’s a little scary, but maybe ok???
OR should I reverse motor, but again, is that a bad idea?
cabmaker
#3 posted 12-16-2013 01:58 AM
Can’t say if it is a bad idea or not without knowing what setup you have there. What is your max at table level?
Are you hand feeding?!
Shawn Masterson
1325 posts in 2187 days
#4 posted 12-17-2013 01:11 AM
You may want to investigate a raised panel cutter.
