question for those that use mineral oil and beeswax for finishing cutting boards
Forum topic by sawedoff posted 12-15-2013 04:54 AM 1598 views 0 times favorited 10 replies Add to Favorites Watch
View sawedoff's profile
sawedoff
154 posts in 2294 days
12-15-2013 04:54 AM
I have been using General Finishes Salad Bowl Finish for my CB’s. I love the look it leaves and the ease of use but can’t stand the smell of it. I purchased some food grade mineral oil and was given some pure beeswax from a friend. I strained the wax and let it set up. I have started selling a good bit of these and think the more natural/organic finish would be better for the people buying them from me
Couple of questions to the folks using both of these to finish boards
1. Do you mix the two ( specific ratio?) and apply when it is warm? If so, do you just reheat and apply with left over mixture? I usually do the top and then about an hour or so do the bottom.
2. How often does the mixture need to be done or is just a touch up coat of mineral oil sufficient for the board periodically?
Any additional info would be greatly appreciated
Thanks
Tyson
-- still wet behind the ears.....
10 replies so far
View Grandpa's profile
Grandpa
3259 posts in 2549 days
#1 posted 12-15-2013 04:59 AM
I don’t use this regularly and have never used the combination. I have used mineral oil alone and I thought it was fine. Just reapply a coat every month or when it looks thin. Mineral oil doesn’t turn rancid. That and the fact that it is safe to consume are the selling points for it.
http://lumberjocks.com/topics/55879
View Biff's profile
Biff
126 posts in 1888 days
#2 posted 12-15-2013 05:23 AM
I use the mineral oil and beeswax mix, I don’t really know the proportions because I mix by eye. Depending on how many boards I’m doing, I would guess I have about 1/4 cup mineral oil with 1/4 to 1/3 cup of beeswax melted in it. The leftover I pour into a Ziploc or pill bottle to give the recipient. All it takes is dunking the bag or bottle in hot water to soften it up enough to apply.
Sometimes I just use mineral oil but if I want the board to really shine when I present it, use the beeswax/mineral oil paste and buff it to a shine.
-- Interested in Oregon property? Visit me at http://www.willamettepropertiesgroup.com
View Bighig50's profile
Bighig50
8 posts in 1498 days
#3 posted 12-15-2013 05:26 AM
I love using bees wax and mineral oil . I use A cheese grader to cut the wax about 1 table spoon per cup of oil. I found A small pot that looks like a crock pot at A yard sale for .50 it works great I plug it in let it heat up then. When I’m finished I put it up to reuse .
-- Bighig South Carolina
sawedoff
#4 posted 12-15-2013 01:04 PM
Thanks guys! Do you normally put a coat of mineral oil on before you put the final mix on? Is one coat plenty?
Thanks again
View pmayer's profile
pmayer
1015 posts in 2939 days
#5 posted 12-15-2013 02:33 PM
I usually put a couple coats of straight mineral oil, followed by the beeswax/oil blend. This provides easier/faster penetration into the board, while the wax top coat provides more luster and a bit more moisture protection so that the board will look better for a bit longer between applications.
sawedoff
#6 posted 12-15-2013 05:38 PM
Perfect. Thx guys. Here a a couple that I have finished recently
sawedoff
#7 posted 12-15-2013 05:42 PM
sawedoff
#8 posted 12-15-2013 05:43 PM
Grandpa
#9 posted 12-15-2013 07:12 PM
Good looking boards. Thanks for sharing.
Bighig50
#10 posted 12-16-2013 01:15 AM
Nice boards
