Band Saw Table
Forum topic by Handtooler posted 12-14-2013 11:26 PM 1331 views 0 times favorited 7 replies Add to Favorites Watch
View Handtooler's profile
Handtooler
1622 posts in 2218 days
12-14-2013 11:26 PM
Topic tags/keywords: resource
LJ’s Can any of you please advise me? I’ve searched as best I can and have gotten dead ends for an after market cast iron table for my Craftsman 12” band saw, the original, which I still use is extruded aluminum. I’m currently using a plywood over table with a left to right fence groove for a tall re-saw fence bolted to a miter gauge, but would like subject fence w/a real “T” track for a decent miter gauge and tall fence. It’d also accommodate magnetized accsesseries.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
7 replies so far
View distrbd's profile
distrbd
2252 posts in 2533 days
#1 posted 12-15-2013 12:08 AM
I have been using the BS table and fence I built after watching the link bellow:
http://www.youtube.com/watch?v=rpbwH9510MY
-- Ken from Ontario, Canada
View kdc68's profile
kdc68
2680 posts in 2363 days
#2 posted 12-15-2013 12:08 AM
May be silly for me to suggest because of compatibility, but have you looked into cast iron tops for a 14”? But being optimistic, this may open up possibilities for a better fence system as well….Good luck in your search
-- Measure "at least" twice and cut once
View Roger's profile
Roger
20931 posts in 2890 days
#3 posted 12-15-2013 12:35 AM
I would go with the link that Ken up above posted. Looks like a good setup. I’ve got that same Powermatic, and I may do what he did in the near future.
View DKV's profile
DKV
3940 posts in 2590 days
#4 posted 12-15-2013 01:20 AM
I also made and use the table referenced in Ken’s post. I think you’ll like it.
-- This is a Troll Free zone.
Handtooler
#5 posted 12-15-2013 01:26 AM
Thanks all! That’s the exact set-up I made about 10 days ago after seeing this video. Yes, It’s improved the use of my saw immensely. But, I’d still be interested in a cast iron table in addition if an after market one is available.
View Nate Meadows's profile
Nate Meadows
1132 posts in 2293 days
#6 posted 12-15-2013 11:22 AM
Russell,
The only idea I have is to make what is not a “aftermarket” cast iron table from another saw and adapt it to yours. You can accomplish this by looking at ereplacementparts.com. They have parts for every tool out there. Find a saw that has the table size you want with the blade through were it is supposed to be. Then, to get it to mount to your saw, if the holes don’t line up, (Which is highly unlikely that they will) first mount the table to a thick sheet of plywood and the rest is easy!. Make sense?
You have to sacrifice resaw height because of the plywood alignment plate. But you will get the rigidity you are looking for.
Nate
-- "With a little bit of faith, and some imagination, you can build anything!" Nate
Handtooler
#7 posted 12-15-2013 02:13 PM
Thanks, Nate. A very good posible solution.
