Setting jointer knives
Forum topic by phil619 posted 12-14-2008 01:12 AM 7540 views 3 times favorited 9 replies Add to Favorites Watch
View phil619's profile
phil619
35 posts in 3688 days
12-14-2008 01:12 AM
Topic tags/keywords: question trick tip
Hello, I’m a long time reader first time poster. I have a Ridgid jointer and I’m having a tough time setting the knives. When I set the knife parallel to the outfeed table and then tighten the lock screws the knife wants to rise. Any suggestions?
-- Building fine furniture in my driveway.
9 replies so far
View tenontim's profile
tenontim
2131 posts in 3981 days
#1 posted 12-14-2008 02:20 AM
Use a piece of wood to hold down the blade, and snug the bolts down a little at a time until they’re tight.
View DustDawg's profile
DustDawg
10 posts in 3850 days
#2 posted 12-19-2008 09:35 PM
I have an 8” Delta X DJ20 which required all of the blades to be changed after running a board through with a hidden nail. A fellow woodworker posted this method on Sawmill Creek and it works flawless for me:
“I took a piece of 1/4 plate glass 5 1/4” x 12”
and super glued 4 rare earth magnets to it.
2 to hold the glass to the out feed table 2 to snatch the knives”.
The magnets hold the knives to the glass which is on the same plane as the out feed table.
Purchased the knives from Global Tooling and also saved a good bit of money:
http://www.globaltooling.net/
Simple and Cheap
Good Luck,
View ChesapeakeBob's profile
ChesapeakeBob
367 posts in 3720 days
#3 posted 12-19-2008 10:01 PM
OK… slightly diffrent topic, but related just the same: I have the DeWalt DW735 planer. I read somewhere about a guy who made a jig for sharpening his three planer knives. DeWalt claims they cannot be sharpened, only replaced, but this guy said, no, they are in fact sharpenable.
Does anyone have experience either with sharpening these knives of remember seeing information concerning the shaprening jig?
Thanks,
Chesapeake Bob, where is it chilly and damp here in MD.
-- Chesapeake Bob, Southern Maryland
View DrDirt's profile
DrDirt
4526 posts in 3979 days
#4 posted 12-19-2008 10:46 PM
The blades on the DW planer can be sharpened so long as they end up with the same dimension for all three.
Because of the way the blades are set with pins, you cannot adjust knives up and down, so like any blade you can sharpen it but just make sure all three match.
I buy blades at global tool and the cost (I know I am falling into that disposable society mold) but I cannot really bring myself to spend the little shop time I get messing around with jigging and grindinv vs. what I would could save by sharpening.
phil619
#5 posted 12-20-2008 09:19 PM
That is a awesome idea DustDog. I purchased the jointer pal which uses the same concept, but the knives would still rise a fraction above the outfeed table. I also used tenontim’s suggestion but with little luck. I finally set the knives a fration low so when I tighten the lock nuts they would rise parallel to the outfeed. Of course there was alot of trial an error. I will definitly try the plate glass method next time, which I hope will be for quite some time.
View Chris Cunanan's profile
Chris Cunanan
339 posts in 3717 days
#6 posted 12-20-2008 09:38 PM
Dave, which global tool is that? a lot of different ones come up, can you give me the link please? I have a 6” geetech (grizzly i believe) jointer and the dewalt 12 1/2” planer, i need 2nd sets on both baddly, to the point where I don’t even use the planer anymore, it’s quite sad =( lol
DrDirt
#7 posted 12-21-2008 04:16 AM
Chris -
This is where I got my Jointer knives from – I have the 6 inch Delta X5
http://globaltooling.bizhosting.com/planer_knives.html
I have the Dewalt 735 Planer and I got the knives from Infinity and have had better edge holding than factory OEM blades
http://www.infinitytools.com/products.asp?dept=1111
they were 59 bucks :-0 for the three knives, versus 55 from Woodworkers Supply for stock parts. But the quality is better than stock ones
View marcb's profile
marcb
768 posts in 3910 days
#8 posted 12-21-2008 09:39 PM
View 8iowa's profile
8iowa
1591 posts in 3998 days
#9 posted 12-22-2008 04:59 AM
Due to the woods tendency to “springback” author Nick Engler recommends that the blades be set .001 to .003 inches above the table at their highest point of their arc. (ref: “Sanding and Planing” Rodale Press 1994)
In regards to the DeWalt planer blades. The hardness of the edge may be only a few thousands deep. Thus sharpening may not produce a keen and lasting edge.
