Behlens Rock Hard Varnish
Forum topic by Gerald Thompson posted 12-13-2013 01:20 AM 1112 views 0 times favorited 1 reply Add to Favorites Watch
Gerald Thompson
1142 posts in 2475 days
12-13-2013 01:20 AM
I plan on using this varnish, with a top grade brush, on a walnut or cherry blanket chest. I have the Behlens Solvent for thinning and plan on using a 50/50 mix for the first coat. The following coats would be thinned 20%. This is gloss and I plan on rubbing it to satin after a 30-40 day cure in the house.
How many coats would suffice? Am I missing anything in my plans? I would wait 24 hours between coats. If I use walnut I will use a walnut colored grain filler of a solvent type.
I would probably shoot the walnut with a 1 pound cut of shellac first before proceeding with any of the foregoing.
Does this seems to be a sound plan? Any experienced help with the application of this product will be appreciated.
-- Jerry
1 reply so far
View Nicky's profile
Nicky
695 posts in 4332 days
#1 posted 12-13-2013 03:28 AM
My experience is using this product on walnut and maple table tops.
I do use a seal coat of shellac, and tint with alcohol based dyes (for walnut.) I’ve not had any problems with the top coats over shellac. I sand to 180, then brush on the shellac. Sand again with 180 then to 220. My first coat of varnish is cut 20%, then two more coats uncut. I sand between coats with 320, just trying to level the coat. For my dining room table, I waited about 3 weeks before I applied some fine rubbing compound and wax, and it looks great.
Although the can says its ready for sanding in 14 hrs, I find waiting 2 days between coats is required.
Sounds like you are using a good brush. Don’t shake the can, or stir to fast, this will create bubble that never seem to disappear.
This product comes in a satin finish.
-- Nicky
