TOOL of the YEAR
« back to Hand Tools forum
Forum topic by b2rtch posted 12-12-2013 11:14 PM 3385 views 0 times favorited 107 replies Add to Favorites Watch
View b2rtch's profile
b2rtch
4861 posts in 3071 days
12-12-2013 11:14 PM
Which tool that you bought since the beginning of 2013 most:
1-improved your work.
2-made your work easier
3-made you a better wood worker
4-made your work safer
For me this tool is very humble and very inexpensive.
This the FastCap Glu-Bot.
I “love” this tool, it makes my life and my work much easier and for very little money.
-- Bert
107 replies so far
View bondogaposis's profile
bondogaposis
4755 posts in 2373 days
#1 posted 12-12-2013 11:24 PM
I’d have to say my wood slicer bandsaw blade. It has made re-sawing so much easier.
-- Bondo Gaposis
View Jeremy Greiner's profile
Jeremy Greiner
568 posts in 2794 days
#2 posted 12-12-2013 11:59 PM
Interesting, I have a glubot (larger version) and had a ton of problems with it. The main bottle seal wouldn’t hold and I found glue squeezing out the top as well as the nozzle made things very messy. Maybe I just got a glitch one. Since then I’ve switched over to using the really cheap squeeze bottles I use for cooking (though I don’t use the glue ones for cooking stuff) http://www.amazon.com/12-oz-Squeeze-Bottles-pk-Clear/dp/B000QJBNII/ref=sr_1_3?ie=UTF8&qid=1386892754&sr=8-3&keywords=squeeze+bottle .. they work great.
-- Easy to use end grain cutting board designer: http://www.1024studios.com/cuttingboard.html
b2rtch
#3 posted 12-13-2013 12:14 AM
This is my second Glu-Bot and both give me satisfaction
-- Bert
View johnstoneb's profile
johnstoneb
2932 posts in 2195 days
#4 posted 12-13-2013 12:19 AM
Delta T2 fence
-- Bruce, Boise, ID
View Les 's profile
Les
201 posts in 2713 days
#5 posted 12-13-2013 12:21 AM
a divorce decree??? Just kidding
-- Stay busy....Stay young
View cutworm's profile
cutworm
1075 posts in 2816 days
#6 posted 12-13-2013 12:29 AM
Probably my Ridgid trim router.
But I also like my Milwaukee M12 radio too. Nice addition.
Merry Christmas to all!
-- Steve - "Never Give Up"
View Kaleb the Swede's profile
Kaleb the Swede
1835 posts in 1992 days
#7 posted 12-13-2013 01:05 AM
My Hitachi MV12 v2 3/14 hp router. I love that thing
-- Just trying to build something beautiful
View JonHitThingWithRock's profile
JonHitThingWithRock
97 posts in 1744 days
#8 posted 12-13-2013 01:15 AM
My grizzly 14” anniversary edition bandsaw with riser block, I no longer have to plane 3/4” off a board to get 1/4” material!!! or the incra ts/ls combo package #1, even a hack like me can make corner post dovetail boxes with this system.
View Nicky's profile
Nicky
695 posts in 4114 days
#9 posted 12-13-2013 01:35 AM
The Micro Jig GRR-Ripper. I now own 2.
It did not improve my work or make me a better woodworker, and I’m always looking to improve.
It does make ripping thin stock easier and much safer.
-- Nicky
b2rtch
#10 posted 12-13-2013 01:45 AM
I have the Micro Jig Thin Kerf SteelPRO and I alos “love” them, great tool
-- Bert
View whitebeast88's profile
whitebeast88
4128 posts in 2213 days
#11 posted 12-13-2013 01:47 AM
probably my used delta jointer off craiglist.didn’t realize how useful a jointer is until i started using it.
-- Marty.Athens,AL
View barringerfurniture's profile
barringerfurniture
223 posts in 1734 days
#12 posted 12-13-2013 02:02 AM
Band saw!
Before that, all my curved pieces had to be cut rough first with a jigsaw, then I had to make a pattern out of mdf (also with a jigsaw), then clean that up by sanding, then clamp it to the rough-cut piece, then run a flush trim bit. PITA! That was all to avoid flare-out of the jigsaw blade around curves.
I can also cut some of my tenons on the band saw now which is easier sometimes. But perhaps the hugest benefit of the band saw for me is resawing. I resaw close to the desired thickness, then either hand plane or run through the planer without killing myself (or the planer).
I can make ogee bracket legs now. Can cut curves in stock thicker than 1” now, etc. Absolutely love it. It’s a Porter Cable.
-- Scott Barringer, Sacramento, CA barringerfinefurniture.com
b2rtch
#13 posted 12-13-2013 02:14 AM
I am shopping for a 18”band saw.
I would like to find a used one but I just can’t find one in Utah.
I am now looking at a Rikon for $999.00
-- Bert
View mantwi's profile
mantwi
312 posts in 1919 days
#14 posted 12-13-2013 02:40 AM
Vega Pro 40” saw fence. It’s my second Vega fence, the first came on a Powermatic 63 Artisan saw years ago. It’s a vast improvement over the fence that came on the 22 year old Grizzly 1023 I restored.
View dan81's profile
dan81
48 posts in 2008 days
#15 posted 12-13-2013 02:42 AM
My hands down favorite tool of this year is my Lee Valley Bevel-Up Jointer hand plane. The thing is so easy to adjust and work with. I bought the PM-V11 blade. I like it a lot.
-- Glue-up is still the stage when everything that was perfect in dry-fit goes horribly wrong, but I'm working on it.
showing 1 through 15 of 107 replies
