Measuring and Marking a radial thickness for rings
Forum topic by Lentze posted 12-12-2013 09:19 PM 837 views 0 times favorited 5 replies Add to Favorites Watch
View Lentze's profile
Lentze
14 posts in 1648 days
12-12-2013 09:19 PM
Topic tags/keywords: marking measuring measure ring thickness gauge
Hello,
I am wondering if anyone knows of a gauge of some sort that can help me with my wood rings.
I need to measure a certain thickness and mark it on the wood ring in a circle so I know how far to sand.
Basically – I drill the inner hole, use a hole cutter and cut the outer circumference, then I need to sand the outer circumference down closer to the inner circumference. The last part needs to be exact so I am just looking for a way to scribe a line on the wood. A similar idea as the rolling marking gauges, but a bit different.
Thanks!
5 replies so far
View Danpaddles's profile
Danpaddles
573 posts in 2306 days
#1 posted 12-12-2013 09:36 PM
A compass? Or am I missing something here?
-- Dan V. in Indy
Lentze
#2 posted 12-12-2013 10:10 PM
Yes – just like a compass – but instead of a needle on the stationary end, maybe a roller or something to help guide it along the inner circumference.
I tried a regular compass and it was too hard not to let the angle it was held at interfere with the line drawn. I need a steadier way to get it to mark.
View JustJoe's profile
JustJoe
1554 posts in 2033 days
#3 posted 12-12-2013 10:36 PM
trammels or a beam compass would be better than a regular compass. They sit close to the surface and it doesn’t matter if you get limp-wristed.
Something like this
http://www.leevalley.com/en/wood/page.aspx?p=32630&cat=1,42936
But if you look around your workshop or google a bit you’ll figure a way to make your own for a lot cheaper.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
Lentze
#4 posted 12-12-2013 11:48 PM
Thanks! Yep – probably something like a trammel, but for very small rings.
View tomd's profile
tomd
2155 posts in 3765 days
#5 posted 12-13-2013 12:10 AM
Why not use a compass before you cut out the middle ?
-- Tom D
