Hardwiring Tools
Forum topic by Oosik posted 12-12-2013 08:29 PM 1248 views 0 times favorited 10 replies Add to Favorites Watch
View Oosik's profile
Oosik
126 posts in 1649 days
12-12-2013 08:29 PM
Anyone have some pictures to show how they have hardwired some tools in? Plug-in seems easier to have a line ran and plug put in place. Is hardwiring any different, instead of a plug have a switch box in place?
10 replies so far
View tefinn's profile
tefinn
1222 posts in 2403 days
#1 posted 12-15-2013 02:34 PM
The only time there would ever be any need to hardwire a tool would be in a commercial shop. I’d never hardwire my tools. Think of the problems if you ever needed to work on or move the tools. Unless each had it’s own circuit you’ld have to shut down power to multiple tools. In any of the commercial or production shops I’ve worked, each tool had it’s own breaker box to shut down and lock out that tool so it could be workd on. Do you really want that kind of expense?
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
Oosik
#2 posted 12-15-2013 04:25 PM
So the saws that grizzly has labeled as hardwire are more for permanent shops?
The cord and plug models are meant for smaller shops then?
I was comparing the G0690 and G1023 and the wiring is a big factor for me.
View JJohnston's profile
JJohnston
1622 posts in 3257 days
#3 posted 12-15-2013 04:36 PM
I just looked at the downloadable manuals for those 2 saws, and they aren’t hardwire. Both call for plugs. I think the 0690 comes with one, but the 1023 doesn’t, but you just attach one to the end of the cord.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View JustJoe's profile
JustJoe
1554 posts in 2004 days
#4 posted 12-15-2013 04:36 PM
I’m not sure where/what specs you’re reading, but neither one of those saws requires hard-wiring. Both are single phase 220V. The G1023 is discontinued but the manual clearly states you need to provide your own plug to match your outlet – that’s not uncommon when buying larger power tools. And the G0690 has the same power requirements but comes with a cord already attached.
Edit: JJohnson typed faster than me. So sorry for beating a dead horse.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
tefinn
#5 posted 12-15-2013 04:48 PM
What they’re saying is that the tool can be permanently hardwired if you want to do so. I’m saying IMO there is no need to for home or hobbiest use. You only need to have the proper voltage and outlet for the plug. For both of these saws 220v.
Shawn Masterson
1325 posts in 1914 days
#6 posted 12-16-2013 12:38 AM
also if you hard wire a machine they need to have a disconnect.
Oosik
#7 posted 12-16-2013 02:47 AM
Is it safe to add a plug? I was reading that sometimes that it is not safe but my knowledge with electrical work stops at replacing a light switch.
I was looking at the G1023RLWX 5hp too, sorry for not being more specific. I now notice the smaller models of that saw have a cord and plug according to the comparison charts.
Anything I should know about 220 vs 240?
tefinn
#8 posted 12-16-2013 03:06 AM
220 and 240 are the same, the voltage numbers are “nominal”.
I checked the manual on Grizzly’s site. This saw does require it to be hardwired. That means you will need a 220 dedicated circuit with a disconnect between it and the saw. If your “knowledge with electrical work stops at replacing a light switch”, hire an electrician to do this work.
Shawn Masterson
#9 posted 12-16-2013 03:06 AM
as long as the plug has the right amperage rating then yes you can put a plug on anything. I have a 10hp phase converter with the same 50 amp plug as my welder, so I can use the outlet for either one. as for 220 vs 240 anything ranging from 220 to 260 is the same the machines don’t know the difference. The fluctuation in voltage is caused by how far you are from the transformer.
View KS_Sparky's profile
KS_Sparky
26 posts in 1589 days
#10 posted 12-16-2013 05:00 AM
If your home shop has a line to line voltage of anything close to 220V or 260V, you have some major issues. You don’t want to be more than 3% (5% max) away from your nominal voltage, which is actually 240V. 220V is an obsolete nominal voltage. If voltages stray too far, motors work harder and electronics can be damaged.
I’d put a cord cap on to match your 240v receptacle, but it wouldn’t be difficult to hardwire it, either. From an NEC standpoint, the cord can be considered the disconnect as long as the plug is accessible. If you hardwire it, the circuit breaker could be the disconnect if it is within sight (or lockable but this won’t apply in a residential panel). If it is an existing branch circuit you should make sure the ampacity is appropriate for your equipment. The equipment amperage shouldn’t be more than 80% of the breaker amperage.
-- apprentice Electrician, IBEW L.U. 226
