Breaking blades
« back to Scrollsawing forum
Forum topic by ALBeam posted 12-12-2013 05:10 PM 790 views 0 times favorited 3 replies Add to Favorites Watch
View ALBeam's profile
ALBeam
25 posts in 1903 days
12-12-2013 05:10 PM
Topic tags/keywords: question scroll saw
I recently got a Skil 16” Scroll Saw and am having trouble with blades breaking. i’ve adjusted the tension with no change. They all break at the same place, just as the teeth begin at the top of the blade. Could this just be cheap blades or something out of sync with the saw itself?
-- -"He is no fool who gives what he cannot keep to gain what he cannot lose." Jim Elliot
3 replies so far
View jordanp's profile
jordanp
1086 posts in 1907 days
#1 posted 12-12-2013 05:16 PM
Normally when i break blades in my scroll saw it is because I have it overtightened, or i’m applying too much pressure when cutting thicker stock. I would maybe try another brand/package of blades and rule that out.
-- J. Palmer Woodworks - Rockwall TX -I woke up this morning thinking “man, I really hope someone posted some soul scarring sh*t on LJs today.” -- - Billy
View oldwormy's profile
oldwormy
16 posts in 1857 days
#2 posted 12-13-2013 01:48 AM
You can over tighten the clamps and break blades. More tension is better than less. Since it is breaking at the holder maybe the top holder is out of line. Put a blade in the top without putting it in the bottom and see if the blade tilts to one side or the other. If so, the clamp screws need work.
-- AlW
View distrbd's profile
distrbd
2252 posts in 2413 days
#3 posted 12-13-2013 02:01 AM
Or you blade are dull and you are forcing the wood against it to cut,you know scroll saw blades get dull after 1/2 hour of use ,depending on the type/thickness of the wood .
I think you should try Flying Dutchman blades,start with Polar #3 and tension it well ,adjust the speed accordingly and you’ll be good to go.
-- Ken from Ontario, Canada
