Jointer Push Blocks
Forum topic by Mike posted 12-12-2013 03:06 PM 2508 views 0 times favorited 5 replies Add to Favorites Watch
View Mike's profile
Mike
406 posts in 2716 days
12-12-2013 03:06 PM
Topic tags/keywords: jointer push block safety
Hi all;
I recently ran into a problem with the safety push blocks I use on my jointer. Over time the pads on the bottom aren’t gripping the boards and they are starting to slide. As many of you know, this can not only get frustrating but also dangerous since your hands can slip.
Instead of just going and buying a new set, does anyone know of a way that I can make them grip again without causing damage to the board?
Thanks for the support,
Mike
-- look Ma! I still got all eleven of my fingers! - http://www.lepelstatcrafts.etsy.com - https://www.youtube.com/channel/UCppWfrYGXCr5lm9uW-Fpqqw
5 replies so far
View Picklehead's profile
Picklehead
1041 posts in 1958 days
#1 posted 12-12-2013 03:35 PM
I cleaned mine and then spray-adhesived 60 grit sandpaper to them.
-- You've got to be smarter than the tree.
View syenefarmer's profile
syenefarmer
492 posts in 3109 days
#2 posted 12-12-2013 03:51 PM
For shorter length stock something like this push block works well.
http://www.woodworkingplans.tv/workshop/make-a-push-block-for-face-jointing
View abie's profile
abie
875 posts in 3800 days
#3 posted 12-12-2013 03:58 PM
Go to any hardware store buy a float( used in concrete) attach cleats ala wire protection studs, attach to the float..
very easy and mentioned in FWW Feb 13
-- Bruce. a mind is like a book it is only useful when open.
13609 posts in 3370 days
#4 posted 12-12-2013 04:06 PM
here are the best i’ve ever seen
very simple
http://lumberjocks.com/MartyBacke/blog/38826
5002 posts in 2522 days
#5 posted 12-12-2013 04:33 PM
Replace the foam with pieces of a new mouse pad.
