[Poly] Finish all sides at once or one at a time? Control drips?
Forum topic by ChuckH posted 12-11-2013 09:06 PM 1036 views 0 times favorited 5 replies Add to Favorites Watch
View ChuckH's profile
ChuckH
70 posts in 1764 days
12-11-2013 09:06 PM
I’d like to hear how people finishing boards. I’m using Minwax Polyurethane. I apply the top and poly runs down the sides of the board. Then I come back with a mostly dry brush and try to even out the sides, but I usually end up having to sand them a bit. Then I’ll flip it and do the bottom – again trying to manage the drips that run down the side.
Any clever tricks to manage this better, or do all four sides of the board at once?
5 replies so far
View pintodeluxe's profile
pintodeluxe
5658 posts in 2811 days
#1 posted 12-11-2013 09:15 PM
I use painters pyramids. I spray the back of the board, then flip it over on the pyramids and spray the edges and top. I can spray two coats of lacquer in one day.
View chrisstef's profile
chrisstef
17384 posts in 3004 days
#2 posted 12-11-2013 09:25 PM
I just picked up those little pyramid gizmos. Love em.
View Earlextech's profile
Earlextech
1161 posts in 2688 days
#3 posted 12-11-2013 09:30 PM
Top and all four edges at the same time. Flip it. Bottom and all four edges at the same time. Sand. Repeat.
View SuperCubber's profile
SuperCubber
1026 posts in 2282 days
#4 posted 12-12-2013 01:33 AM
This may sound overly simple, and maybe it is, but make sure you are brushing toward the edge as much as feasible. Starting at the edge leaves a buildup of material that can easily drip down the side.
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
View gfadvm's profile
gfadvm
14940 posts in 2687 days
#5 posted 12-13-2013 02:49 AM
I really prefer the wipe on poly/ms mixture. No drips and dries much quicker. BUT does require more coats.
