Drillpress for sharpening lathe tools ?
Forum topic by sgv posted 12-11-2013 03:18 PM 837 views 0 times favorited 3 replies Add to Favorites Watch
View sgv's profile
sgv
266 posts in 2130 days
12-11-2013 03:18 PM
In my shop today looking at two drill presses I have and was thinking 1) Can you sharpen lathe tools on a drill press Horizontal instead of vertical ? 2) I would have to make a jig for the tools to rest in ? 3)Any one ever tried this ? and if so how did it work ?
I have the mandrel, the drill press, the scrap wood. The only thing I would need is the grinding wheel.
Any though?? As all ways Thanks to all LJs
-- Tite Lines, May the wind be at your back
3 replies so far
View MrRon's profile
MrRon
5263 posts in 3481 days
#1 posted 12-11-2013 03:37 PM
No reason why it wouldn’t work, but if the DP has any runout or lateral play, it could affect sharpening. Bench grinders have bearings that ensure a perfectly spinning wheel. Try; you have nothing to lose.
View PaulDoug's profile
PaulDoug
1717 posts in 1941 days
#2 posted 12-11-2013 03:38 PM
My concern would be that on most drill presses the chuck is fasten to a tapered shaft that is pressed in. If that came loose with a fast spinning heavy grinding wheel on it, could be very dangerous. I have never tried it. I don’t know if my concern is valid.
View sgv's profile
sgv
#3 posted 12-11-2013 03:38 PM
Thanks MrRon and PaulDoug, still milling it over
