Oops! Clarification on question about rabbeting back of cabinet doors
Forum topic by patchencindy posted 12-11-2013 03:41 AM 1226 views 0 times favorited 7 replies Add to Favorites Watch
View patchencindy's profile
patchencindy
32 posts in 2245 days
12-11-2013 03:41 AM
Topic tags/keywords: rabbet frame-and-panel doors cabinet doors overlay lipped
Sorry, but I accidentally call the rabbets on the backs of lipped overlay cabinet doors “dados.” Maybe this’ll make more sense:
I’m making slow but steady progress on a floor-to-ceiling kitchen cabinet, to the point where I’m working on the frame-and-panel doors. The cabinet has a face frame, and the doors (3/4” pine with birch plywood panels) are designed to partially overlay the frame. I had originally planned to cut a 3/8” rabbet on the back edges of the doors so they’d have a lip that caught on the frame, yet would also fit into the face frame opening, but now I’m wondering if there’s a purpose or advantage to doing that. Does anyone have thoughts on this?
7 replies so far
View Lifesaver2000's profile
Lifesaver2000
556 posts in 3350 days
#1 posted 12-11-2013 04:46 AM
One purpose is to create a more low-profile look for the door, in that it has only 3/8 visible instead of 3/4 outside the face frame. I personally like that look a lot compared to full overlay, but it depends on the project. I used the partial overlay on my bookcase gift project last year and I think it turned out looking really good. You can see it in my projects: http://lumberjocks.com/projects/75954
patchencindy
#2 posted 12-11-2013 02:05 PM
Nice piece, Lifesaver! And thanks for the response. I guess the choice is mainly aesthetic.
16281 posts in 4456 days
#3 posted 12-11-2013 02:20 PM
I agree with Lifesaver…. it’s a very nice look, but purely an aesthetic choice. It also ups the degree of difficulty a bit, so if you are new to cabinet-making you may want to take that into consideration.
View Gene Howe's profile
Gene Howe
11147 posts in 3666 days
#4 posted 12-11-2013 02:36 PM
If everything is square, and you have a decently sized router table it’s not TOO difficult. IMHO, not worth the bother, though.
patchencindy
#5 posted 12-11-2013 05:44 PM
Well, the doors and face frame openings are square, but I must admit I’m a little reluctant at this point to risk destroying the doors with a slip of the router. I did the mortises and tenons and the grooves on the door frames for inserting the panels all on the table saw, and I guess I should’ve cut the rabbets at pre-assembly, too. Live ‘n’ learn. Thanks, all!
Gene Howe
#6 posted 12-12-2013 03:01 PM
I can understand that, for sure.
Have you considered an ogee around the perimeter of the frames? that would effectively reduce the edge thickness….if that’s what you’re looking for. And, that can be done with a hand held router. A bit less cumbersome than using the table.
patchencindy
#7 posted 12-12-2013 04:06 PM
You’re right, Gene. That is an excellent compromise solution. Again, my hesitation is that I’m not as adept with the router as I am with the table saw. Would hate the botch the doors at this late stage. An ogee would also soften the look, which would be a good thing.
