Re-using an old floor
Forum topic by Withers posted 12-11-2013 12:02 AM 970 views 0 times favorited 7 replies Add to Favorites Watch
View Withers's profile
16 posts in 1578 days
12-11-2013 12:02 AM
I salvaged an old wooden floor from a house i was remodeling. i have three thrash bag full of this stuff, the problem is that 1.i need to remove the floor adhesives and old stain and scrathes to make it usable
2. they are very small pieces. i didnt put a reference in the picture but they are roughly 1”x 4” x 1/4”
i was using my belt sander to get the adhesive and stain off but couldnt really figure out a way to get it perfectly flat on the faces or edges. which is imperative for how im going to be repurposing them. which is gluing a bunch of them together to make a larger board for cabinet faces and other facades. i tried doing this after cleaning them up on the belt sander but there where gaps EVERYWHERE!
i want to reuse all this wood since ive got it. Anyone have any ideas?
-- If you love what you do, you'll never work a day in your life
7 replies so far
View deon's profile
2522 posts in 2959 days
#1 posted 12-11-2013 05:32 AM
Plane them (if there are no broken nails left inside)
-- Dreaming patterns
View watermark's profile
483 posts in 1876 days
#2 posted 12-11-2013 05:40 AM
I don’t have a lot of experience but a small bench top jointer may do the trick? Like Deon said ^^ no nails is important. They might be too short for a jointer is the only thing, if not may be a good way to do it efficiently. Anyone with more experience feel free to chirp in and say it’s a bad idea.
-- "He who has no dog, hunts with a cat" Portuguese proverb
View REO's profile
928 posts in 2007 days
#3 posted 12-11-2013 08:33 AM
if the floor was put in the earlier than the late seventies there is a good chance that the adhesive contains asbestos. take care.
View Jake's profile
850 posts in 1564 days
#4 posted 12-11-2013 09:32 AM
If your disc sander is large enough, you can just make a jig that pushes it flat against the sander, with 60 to 100 grit, you should be able to crank them out pretty quickly.
That is assuming that the top side is flat, if that is not the case then a small bench top jointer seems the best option, because you need both sides perfectly flat.
-- Measure twice, cut once, cut again for good measure.
View fuigb's profile
471 posts in 2891 days
#5 posted 12-11-2013 05:41 PM
Looks like you’re trying to bring back material from a parquet floor. If so then you have a lot more patience than I can muster. I have such a floor and the plan is to have a big bonfire once it comes up and is replaced, and this is saying something because I’m an avid searcher for and user of reclaimed material. Too damn small and tedious in this case.
A combination of stationary belt sander and then hand planing is where I’d start if I had no choice in taking on this assignment.
Good luck, Withers. No shame in reporting back that you chucked the project and spent your time on something else.
-- - Crud. Go tell your mother that I need a Band-aid.
View alohafromberkeley's profile
257 posts in 2337 days
#6 posted 12-11-2013 06:40 PM
Carbide scraper with a long handle. Clamp a few together then scrape one side, flip over scrape other side. The faces will have to be done one at a time.
-- "After a year of doing general farmwork, it was quite clear to me that chickens and I were not compatible"-George Nakashima
View gfadvm's profile
14940 posts in 2623 days
#7 posted 12-13-2013 02:43 AM
I use my drum sander with some 24-50 grit paper.
