belt size for woodmaster stroke sander
Forum topic by sawedoff posted 12-10-2013 10:43 PM 2113 views 0 times favorited 3 replies Add to Favorites Watch
View sawedoff's profile
sawedoff
155 posts in 2389 days
12-10-2013 10:43 PM
I just bought a woodmaster w-800 stroke sander. Problem is that it didn’t come with a manual and I was unable to get any info from Woodmaster since they dont produce these anymore. I have done an online search and came up with multiple answers. It did come with several belts and I laid them out flat and measured them then multiplied by 2. I came up with 77.5×2 = 155” belt. I have seen anywhere from 143 to 165 online. Do any LJ’s out there have this machine? If so I’d sure appreciate any info you could pass along.
As always, I really appreciate the great info I get from this site
Thanks
Tyson
-- still wet behind the ears.....
3 replies so far
10283 posts in 3617 days
#1 posted 12-11-2013 12:08 AM
This article I found doesn’t answer your questions but it has some
useful info at the end on using stroke sanders and making belts.
http://books.google.com/books?id=dvsDAAAAMBAJ&pg=PA39&dq=woodmaster+stroke+sander&hl=en&sa=X&ei=oqqnUpvSI8r0oASn54LICg&ved=0CEYQ6AEwAA#v=onepage&q=woodmaster%20stroke%20sander&f=false
I’m skeptical of the ability of packing tape to hold belts together,
but the author seems confident.
I have a stroke sander too. I haven’t used it much yet but I’m very
impressed with what I’ve seen.
sawedoff
#2 posted 12-11-2013 12:18 AM
Thanks Loren! I will check it out
View Woodendeavor's profile
Woodendeavor
276 posts in 2576 days
#3 posted 12-11-2013 12:37 AM
You can get belts from manufacturers no problem. I do not have a stroke sander but I order custom belts for my edge sander all the time. All my belts are custom cut for me from large rolls, they can do any size you would need. I use Keystone abrasives, Wood pro is their abrasive I use the most
