reclaimed wood finishing
Forum topic by drpdrp posted 12-10-2013 12:41 AM 930 views 0 times favorited 4 replies Add to Favorites Watch
View drpdrp's profile
drpdrp
150 posts in 2039 days
12-10-2013 12:41 AM
Suggestions on the balance between all of the texture and scarring adding to the look vs. touchability?
I was thinking maybe sanding with only a high grit.
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2348 days
#1 posted 12-10-2013 06:41 AM
Wire brush, then coat with something. Wax or even poly.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
drpdrp
#2 posted 12-10-2013 08:09 AM
Theory being a wire brush will knock off any pokey bits without leaving fresh scratches?
View hydro's profile
hydro
208 posts in 1745 days
#3 posted 12-10-2013 02:45 PM
Leave some tool marks on the surfaces. I will use a sharp card scraper to add some texture to flat surfaces, bowing it as I make the cuts. On curves I will leave the marks from whatever I used to cut the surface, such as a block plane, chisel, etc. If you want the surfaces a bit softer, try using a gray or red scotchbrite pad to knock off the sharpness. Don’t use steel wool, particularly on oak as will leave bits of metal that may discolor later.
You can try a wire brush, or a wire wheel in a drill, but I have not found these methods to be particularly effective in adding texture. They tend to just burnish the surfaces.
-- Minnesota Woodworkers Guild, Past President, Lifetime member.
View Clint Searl's profile
Clint Searl
1533 posts in 2355 days
#4 posted 12-10-2013 03:40 PM
Wire brush and waterborne poly.
