Citric Acid vs. Electrolysis
« back to Hand Tools forum
Forum topic by robdbeal posted 12-09-2013 10:28 PM 2655 views 0 times favorited 4 replies Add to Favorites Watch
View robdbeal's profile
robdbeal
9 posts in 1742 days
12-09-2013 10:28 PM
Topic tags/keywords: stanley bailey handplane citric acid electrolysis rust
Hi everybody, I’m just trying to get started with some woodworking and I’ve found some old Stanley Bailey planes at antique stores with the usual antique “patina” included. I would like to use them and they need to be cleaned of rust. I’ve seen where some use citric acid and some use electrolysis. Are there pros and cons for either one or is there one I should definitely stay away from? Thanks for any info you can give me.
View Don W's profile
Don W
18554 posts in 2437 days
#1 posted 12-09-2013 10:34 PM
Electrolysis takes the right equipment, like a battery charger it some other electrical source. With citric you just add water.
View ChuckC's profile
ChuckC
825 posts in 2804 days
#2 posted 12-09-2013 11:28 PM
I’ve done electrolysis but prefer EvapoRust. It’s not toxic and you just soak the part for a day or so and it works very well.
View TerryDowning's profile (online now)
TerryDowning
1074 posts in 1987 days
#3 posted 12-09-2013 11:35 PM
Vinegar is also a viable low strength acid for rust removal. Just remember if you use citric acid or vinegar wax or oil the de-rusted item soon after as the citric acid or vinegar do contain water and flash rust can form.
Other items that make rust removal easier brass cleaning brush (like a tooth brush) removes the rust without scratching the iron. WD-40 and a variety of wet/dry sand paper grits.
Enjoy and show pics as you progress.
-- - Terry
View Jesse.R's profile
Jesse.R
55 posts in 2794 days
#4 posted 12-09-2013 11:59 PM
vinegar works well. soak it overnight scrub the rust off the next day and rub it down with baking soda to neutralize the acid left over then seal it and your good to go.
-- jesse
