Delta 22-560 planer dust collection solution
Forum topic by Chris208 posted 12-09-2013 06:05 AM 2602 views 0 times favorited 2 replies Add to Favorites Watch
View Chris208's profile
Chris208
239 posts in 2264 days
12-09-2013 06:05 AM
A while back, I bought a delta 22-560 planer that did not include the factory dust collection fitting. This thing, like all planers, shot shavings all over the place and was a top mess-maker in my garage shop.
I had seen dust collection solutions on LJs but what I saw seemed complicated, which discouraged me., so I kept putting it off.
Last Saturday I went out in the shop determined to build a dust collection solution for my planer.
I was only hoping to build a prototype, so I quickly put together a fixture of 1/4” MDF, held together with clinched nails. I bought the plastic dust collection fitting at woodcraft for $6.
The 22-560 has a spring loaded switch that is depressed by the factory blade guard. This switch must be depressed in order for the planer to operate. I cut a small piece of sheet metal, inserted it, and screwed it down using the factory screw hole for the blade guard.
This thing is ghetto as all get out, but hell if it don’t work. It collects very nearly all of the planer shavings. The only downside is that some planer shavings collect inside the housing, which I just suck out with a shop vac from time to time.
This thing is not sealed in any way, and still does an amazing job of collecting chips. I can’t believe I waited so long to tackle this.
When this one falls apart, which it undoubtedly will, I’ll build one more sturdy.
2 replies so far
View pmayer's profile
pmayer
1028 posts in 3059 days
#1 posted 12-09-2013 02:36 PM
That is a great solution, much nicer than the plastic stock one that they sell. If you put some angled blocks on the corners I bet you would never have to clean it out. I had that planer for several years and I wish I would have built this. I had to take the dust port off on a monthly (or so) basis to unclog it because the chip path was only about 3/4”. Way too skinny. Nice work!
4981 posts in 2487 days
#2 posted 12-09-2013 03:09 PM
Well done! I’m not sure why you reference it as “ghetto”, I think it looks just fine. Especially if it works well.
