GLUE
« back to Coffee Lounge forum
Forum topic by Edwin posted 12-08-2013 06:09 PM 1227 views 0 times favorited 12 replies Add to Favorites Watch
View Edwin's profile
Edwin
139 posts in 3020 days
12-08-2013 06:09 PM
I have a gift I am working on for my Daughter in law for Christmas. My shop is unheated and I have to glue up some stiles for her jewelry box. It’s cold out 31 degrees. I am using Titebond wood glue, I know i shouldn’t use it. Are there any other alternatives…..
Thanks ED
-- Ed Port Republic
12 replies so far
View cajunpen's profile
cajunpen
14575 posts in 4088 days
#1 posted 12-08-2013 07:13 PM
Hi Ed, I don’t know the answer to your question – but I am wondering the same thing, so I will be following this post, thanks for asking it.
View Jim Jakosh's profile
Jim Jakosh
20580 posts in 3127 days
#2 posted 12-08-2013 07:40 PM
I would use 5 minute epoxy. It chemically cures. I think that is what I would use if I could not warm up the pieces…................Jim
View patcollins's profile
patcollins
1685 posts in 2887 days
#3 posted 12-08-2013 07:46 PM
Temperature affects epoxy also, the cold slows down the chemical reaction and 5 minute epoxy could become 5 hr epoxy or may not cure at all. If you can heat your shop with a portable heater or bring your glue up inside.
50 degrees F should be fine for wood glue if you give it enough time.
View matt garcia's profile
matt garcia
1896 posts in 3694 days
#4 posted 12-08-2013 08:02 PM
I would wait until it warms up or glue it up and let it cure inside.
-- Matt Garcia Wannabe Period Furniture Maker, Houston TX
35125 posts in 4422 days
#5 posted 12-08-2013 08:02 PM
I don’t know the size of your pieces, I’d either carry them into the house to glue up or you might try a microwave. I use around 30 seconds to 1 minute to microwave my glue joints. If the wood is hot enough to handle than that is enough. And you can usually continue on with your processing.
It like makes it instant set.
Furniture MFG’s do that all the time but they use a hand wand to hold against the glue joint to set the glue and continue their processing.
They use radio frequency curing and I figured if radio frequency worked that micro wave should also work. I tested it and it does.
Good Luck.
I was reading some test values and they stated that 100 sq inches of glue line would cure in one minute with 1kw of power. So it you have a 1000 watt microwave it should cure 100 sq inches in one minute.
I developed this for use in workshops where we didn’t want to take 2 days to do 1 days work, because we had to wait for the glue to dry. I use rubber bands for clamps so I don’t put metal clamps in the microwave.
#6 posted 12-08-2013 08:17 PM
Another little tip is use some salt in the glue line. Salt will keep the two pieces from sliding when you are clamping them. And, salt also makes the glue more conductive so that it will cure faster. They state no more than 2% salt for the glue. So just have a shop salt shaker and sprinkle it on top of the glue.
#7 posted 12-08-2013 08:23 PM
Another great article on Radio frequency gluing
View tinnman65's profile
tinnman65
1357 posts in 3436 days
#8 posted 12-08-2013 09:37 PM
My first thought is that if its small enough bring it inside while the glue dries or cover it with a heating blanket if it must be left in the shop.
-- Paul--- Creativity is allowing yourself to make mistakes. Art is knowing which ones to keep. — Scott Adams
View lew's profile
lew
12099 posts in 3777 days
#9 posted 12-08-2013 10:29 PM
I like Karsons idea, if your pieces will fit into the microwave.
Edwin
#10 posted 12-08-2013 10:55 PM
Thank you all for your comments. I’ve learned a lot. I never knew about the microwave, good idea BUT I don’t think my bride would approve. The heating blanket is a good idea also. Thank you Karson for your article on Radio frequency gluing. Very interesting… But now I think I’ll watch some football, Besides that it’s starting to sleet out and it’s dark… Theirs always tomorrow… Ed
-- Ed Port Republic
#11 posted 12-09-2013 12:18 AM
There’s no smell or any damage done to the microwave. I mean she has to go shopping sometime.
View Roger's profile
Roger
20928 posts in 2826 days
#12 posted 12-10-2013 02:20 AM
Hummmm. If possible, ask Santa for a heated shop
