Layout tool
Forum topic by MrRon posted 12-07-2013 07:34 PM 1376 views 0 times favorited 4 replies Add to Favorites Watch
View MrRon's profile
MrRon
5264 posts in 3481 days
12-07-2013 07:34 PM
Here is a tool I made for laying out dimensions on sheet goods with greater accuracy than a tape measure can deliver. To use it, you start from one edge and adjust the caliper until you get the dimension you want. You then scribe a mark at the end of the tool. When larger dimensions are needed, adding flat bars in increments of 6” and 12” extends the range. I designed this tool around a Harbor Freight digital caliper, but they also have calipers that read in fractions. I use this to layout large parts for model locomotives where decimal readings are necessary, but for general woodworking, a fractional reading caliper will be better.
View Kelly's profile
Kelly
2187 posts in 3182 days
#1 posted 03-03-2015 03:33 AM
Gonna watch this and look at it closer. Me thinks it deserves it and the result would be to my benefit.
Thanks
MrRon
#2 posted 03-03-2015 04:27 PM
I made this tool, but had to revise it somewhat because the HF caliper I used was hardened stainless steel and I couldn’t drill through it. I ended up using a clamping arrangement which wasn’t rigid enough for my liking. I could get a caliper made from resin that I could drill, but the HF one reads only in hundreds of an inch. I need one to read in thousands. Still it works.
Kelly
#3 posted 03-03-2015 04:53 PM
If you can, toss in a photo of the prototype. It would be appreciated.
MrRon
#4 posted 03-04-2015 10:33 PM
- Kelly
Sorry, but since I wasn’t happy with the way the tool turned out, I took it apart.
