Looking for the cheap stamped press-on brass hinges. (Found!)
« back to Joinery forum
Forum topic by JustJoe posted 12-05-2013 05:21 PM 2174 views 1 time favorited 21 replies Add to Favorites Watch
View JustJoe's profile
JustJoe
1554 posts in 1947 days
12-05-2013 05:21 PM
I’m looking for those brass hinges you see on cheap wooden boxes They’re small and thin and don’t take screws. The outer edge of each leaf is bent 90 degrees and serrated and it is pressed into the wood. You usually see them on throwaway type boxes if that makes sense.
Anyone know what they’re really called, and where I can buy a couple dozen for cheap?
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
21 replies so far
View waho6o9's profile
waho6o9
8100 posts in 2485 days
#1 posted 12-05-2013 06:09 PM
Kinda reminds me of these cigar box hinges.
PM me if you want em. It’s not close to what you need/want but it’s
a couple more than you have.
There about inch and a quarter wide.
View bandit571's profile
bandit571
19230 posts in 2592 days
#2 posted 12-05-2013 06:11 PM
Walk in to Hobby Lobby, and look around..
JustJoe
#3 posted 12-05-2013 10:23 PM
waho6o9 – thanks but I’ll keep searching. I know if I can find the right name for them that I should be able to buy a lifetime supply for a couple of bucks, they’re so cheap.
bandit571 – hobby lobby doesn’t list them on their website under hinges, and I’m too lazy and cheap to burn a gallon of gas to go wandering their aisles. If they had lumber or tools then I might make the drive.
I just have to put my faith in google. Eventually I’ll find the right combination of words and they’ll pop up and I’ll know the correct name for them.
thanks
Joe
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 1981 days
#4 posted 12-05-2013 10:29 PM
Search “press in box hinges” I found these and others. Monroe hinge.
-- Who is John Galt?
JustJoe
#5 posted 12-05-2013 10:31 PM
That sure looks close. I had already tried “brass hinges press-in” and “brass hinges press-on” and got nowhere.
thanks
Joe
joeyinsouthaustin
#6 posted 12-05-2013 10:32 PM
Also barbed hinges, or slot hinges that slid into a slot.
joeyinsouthaustin
#7 posted 12-05-2013 10:47 PM
try these press in barrel hinge? I also searched “press in cigar box hinge” found some stuff on alibaba, but 5000 min order :(
JustJoe
#8 posted 12-05-2013 11:18 PM
Thanks but I’m looking for real thin metal with very thin prongs to press into very thin walls so I can throw some cheap little boxes together to hold hardware – like cigar boxes but 1/5th the size and with lids that stay closed.
View Dark_Lightning's profile
Dark_Lightning
3074 posts in 3017 days
#9 posted 12-06-2013 04:19 AM
I seem to recall that I bought something like this years ago, but don’t remember where. Maybe try Rockler?
-- Random Orbital Nailer
View tefinn's profile
tefinn
1222 posts in 2345 days
#10 posted 12-06-2013 05:08 AM
Try searching for “pronged hinges”. These are just some of what I found.
http://www.utmfg.com/product/HNG-SMALL/HNG-1758.html
http://www.bearwood.com/HARDWARE-HINGE.HTML
http://www.atcoproducts.com/minpronhin.html
http://www.etsy.com/listing/120073903/12-sets-20mm-x-25mm-metal-nickel-hinges?ref=market
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View Oldtool's profile
Oldtool
2548 posts in 2099 days
#11 posted 12-06-2013 01:40 PM
JustJoe,
Not sure exactly what you are looking for, but for a cheap hinge to be used on utilitarian storage boxes, why not glue a piece of cloth on the hinged side of the box?
Food for thought. Good luck in your quest.
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
13594 posts in 3249 days
#12 posted 12-06-2013 01:59 PM
joe
woodcraft has the hinges
and a mandrel and saw for them
they need to be in one time
can’t be taken out
need softer woods too
the hard woods make the prongs flatten
try on scrap first
http://www.woodcraft.com/Product/2003744/7853/Barbed-Hinge-1-18-x-78-Pair.aspx
View Pezking7p's profile
Pezking7p
3217 posts in 1560 days
#13 posted 12-06-2013 02:01 PM
Like this? http://www.umei.com/cb/wood-box-hinge-hg-25.htm
The only other similar items I found were intended to be installed by a machine in an assembly line.
-- -Dan
JustJoe
#14 posted 12-06-2013 02:09 PM
David, those aren’t the hinges I’m looking for either. They’re not cheap or flimsy enough. The ones I want are super-cheap and require no cutting. They are used on real cheap boxes. Most people would be ashamed to use them on anything nice. These are the things used in factories on cheap little boxes made to hold something where the buyer is probably going to throw the box out. A machine rolls the two sides of the box under a press and the press just slaps the hinge on to both pieces and rolls it on down the line.
Tom found them – 50 for $27.50.
Thanks to everyone though, you showed me some other hinges that can be used on nicer stuff.
Joe
#15 posted 12-06-2013 02:12 PM
your link says they arent available joe
but Pezking7p’s are
good luck
