Router Bits: 1/4" VS. 1/2" Shanks.
Forum topic by Micah Muzny posted 12-05-2013 04:33 AM 2138 views 0 times favorited 10 replies Add to Favorites Watch
View Micah Muzny's profile
Micah Muzny
185 posts in 1847 days
12-05-2013 04:33 AM
When it comes to router bits, there are 1/4” and 1/2” shank sizes. What are the pro’s and con’s of each size? Are the 1/2” better in anyway than the 1/4” or vise versa?
10 replies so far
View Timmer's profile
Timmer
1 post in 1749 days
#1 posted 12-05-2013 04:43 AM
The 1/2 shank will vibrate or chatter less at high speeds for a cleaner cut
-- Tim
View Pete_Jud's profile
Pete_Jud
424 posts in 3868 days
#2 posted 12-05-2013 04:53 AM
Only use 1/2 inch shanks in my shop, unless the bit is less than 1/8 inch. Just my rule.
-- Life is to short to own an ugly boat.
View Jim Jakosh's profile
Jim Jakosh
21103 posts in 3220 days
#3 posted 12-05-2013 04:54 AM
The 1/2” can have a larger max cutter on them. You can use a the 1/4” router bits in a 1/2” router with a split collet. Some real small cutters don’t come with the 1/2” shank, too. It is good to have a 1/2” router so you can use all of them. I really don’t notice any difference in using either of them. You just buy what need to get the job done. I started buying only 1/4” ones because that was all my craftsman router would take.
I have seen router bit extensions but I am really afraid to ever try one. If they are not perfectly concentric you will get some bad vibrations with a bit hanging out that far and spinning at 25,000 RPM. I would not think it is very good for the spindle bearing in the router either. I have never had a job that would need a bit sticking our farther than they normally do.
Cheers, Jim
View Loren's profile
10477 posts in 3763 days
#4 posted 12-05-2013 05:12 AM
Some nimble small routers only take 1/4” shanks and for
that they are useful. For handheld use a lighter,
more compact router is nice to work with if the
cuts aren’t too heavy. For router table work 1/2” shanks
are going to perform better.
View Monte Pittman's profile (online now)
Monte Pittman
29784 posts in 2453 days
#5 posted 12-05-2013 06:34 AM
Like any tool, both very useful for different projects. I use the 1/4” shafts with my compact router for doing signs, edging and small projects. I use the 1/2” shanks for heavy duty jobs. For instance the oak poker table I consider to heavy of job for small router tools. I am also lazy. I have 5 routers set up so that I have minimal time changing bits.
View knotscott's profile
knotscott
8120 posts in 3490 days
#6 posted 12-05-2013 10:09 AM
1/4” breaks easier. The only 1/2” bits I’ve ever broken were those they to taper to 1/4” or less near the cutter end, but I’ve broken 1/4” bits right at the shank.
View teejk's profile
teejk
1215 posts in 2799 days
#7 posted 12-05-2013 12:42 PM
I notice longer life on 1/2” which I think is due to heat.
View bondogaposis's profile
bondogaposis
4925 posts in 2466 days
#8 posted 12-05-2013 01:18 PM
The half inch bits ,are definitely better and I use them whenever I can. I still have an old router that only takes 1/4” shank bits and for that reason I still keep a few 1/4” bits around.
-- Bondo Gaposis
View BentheViking's profile
BentheViking
1782 posts in 2679 days
#9 posted 12-05-2013 02:49 PM
my bosch colt router only takes 1/4” my hitatchi 3 1/4” hp only takes 1/2” my craftsman will take both sizes so i guess it really depends on what I’m trying to do.
-- It's made of wood. Real sturdy.--Chubbs Peterson
View laketrout36's profile
laketrout36
200 posts in 2141 days
#10 posted 12-06-2013 02:32 AM
I’ve started using Whiteside 1/2” bits. From my recent experience I’ve got no complaints. The 1/4” bits I’ve used (Not Whiteside) I’ve had to keep a good eye on my work, not too fast, not too slow, no more than 1/8” cut for each pass of the router. Smaller bit, more care is needed in my experience. Just an observation.
