Jet Parallel Clamps - Release lever?
« back to Hand Tools forum
Forum topic by paxorion posted 12-05-2013 03:02 AM 1943 views 0 times favorited 7 replies Add to Favorites Watch
View paxorion's profile
paxorion
1107 posts in 2167 days
12-05-2013 03:02 AM
I just received my (Black Friday splurge) Jet parallel clamps today, and was a bit disappointed in the release lever. Even after pulling up on the level, it’s rather hard to move the clamp head. Out of the 4 I purchased, only 1 of them slides nice and smoothly.
I wanted to know if this is normal for the Jet parallel clamps, and if the operation becomes smoother after some use?
-- paxorion
7 replies so far
View lew's profile
lew
12270 posts in 3877 days
#1 posted 12-05-2013 03:12 AM
Mine are the same. I have to slightly “tilt” (by lifting/pushing on the screw handle- I forget which) the sliding head to get them to move freely.
paxorion
#2 posted 12-05-2013 04:38 AM
Lew – Yep definitely user error. I was fin-nicking around with them just after posting this forum topic, and tried lifting/pushing like what I’ve come to do when playing with the Besseys and Jorgies, and it now works like a charm.
-- paxorion
paxorion
#3 posted 12-12-2013 03:03 PM
All – I thought I’d add a few additional questions now that I have a chance to play around with the clamps a bit more. I noticed that the two 40” clamps still seem to get stuck at various lengths of the bar. On closer inspection, it appeared that there the bars have some dings on them, for example equally spaced at the ruler markers (on the 7, 8, and 9” marks).
While it doesn’t render the clamp inoperable, it does interfere with the clamp head movement, causing a sudden thud and stop when sliding the bar forward or back. I am talking to Jet customer service about this but I am wondering if anyone else has noticed imperfections (such as these) on parallel clamp bars being an issue?
-- paxorion
paxorion
#4 posted 12-18-2013 03:45 AM
All – Just a quick update. After conversing with Walter Meier customer service, I was sent 2 replacement clamps for the 40” clamps that get stuck randomly. The new clamps don’t have the same release lever + binding problem of the original 2 in the set and slide VERY smoothly. Kudos to Walter Meier for the hassle free customer service.
-- paxorion
View twelvepoint's profile
twelvepoint
38 posts in 2084 days
#5 posted 04-15-2014 12:41 PM
I made a note of this in another thread, but this is specifically the issue I’m having with my Jet clamps, too. All 4 of my clamps are very difficult to slide, and when I removed the head to reverse it (for spreading), it wouldn’t even go back on the bar.
I’m pretty sure it’s the spring that’s interfering with the sliding. I took my clamp apart and the spring (has a rectangular cross section that the bar passes through) doesn’t really locate on the locking lever, so it gets hung up easily on the bar’s ridges. I would bet if the steel locking tab had ridges that located the spring away from the bar the slide action would be way better.
View Pezking7p's profile
Pezking7p
3217 posts in 1773 days
#6 posted 04-15-2014 12:45 PM
I considered taking my clamps apart to inspect what the issue was, but I never got very far. I think I took off the face plate, found something more complicated than I liked, and gave up.
I have about half that slide easily and half that slide kind of rough. I hope after some use they’ll free up.
-- -Dan
paxorion
#7 posted 04-16-2014 04:15 AM
After the initial issue with the release lever and positive customer service experience (they let me keep the “defective” clamps), I can say that my clamps have exceeded my expectations and serve me well.
-- paxorion
