How do I fit a top and bottom into finger jointed box?
« back to Joinery forum
Forum topic by mporter posted 12-05-2013 01:52 AM 1797 views 0 times favorited 8 replies Add to Favorites Watch
View mporter's profile
mporter
253 posts in 2574 days
12-05-2013 01:52 AM
I have alway made my boxes with a grove cut by a table saw in the top and bottom of of the side pieces. This grove would allow a piece of plywood to fit into it as a bottom and a figured piece of wood to fit into the top grove for a top. Glue it up-cut the top off on a table saw and presto a box! Well you get the idea.
My question is, I am making a box with finger joints and figured out today in the shop that I can’t cut these grove with a table saw because the grove will now show on the ends. How do I get around this problem? The bottom I can fit in with a rabbet cut with a router bit, but this won’t work for the top. Any suggestions?
8 replies so far
View Tommy Evans's profile
Tommy Evans
146 posts in 2170 days
#1 posted 12-05-2013 02:34 AM
I haven’t worked my way up to boxes yet. LOL, so bear with me. How about if you run the fingerjoints up the corners to a space where you would then cut off the top. Does that make sense? Stop the fingerjoints short of the top the distance you want the top to be cut. If I understand what you mean…
Seems to work in my head, but that’s not saying much!
ooops, forget my answer, the picture in my head just disolved…...
peace, T
View bondogaposis's profile
bondogaposis
4723 posts in 2347 days
#2 posted 12-05-2013 02:39 AM
You have to make stopped grooves on the sides that show, 2 sides won’t show because they will be covered by the fingers. The easiest way to do that is make the stopped grooves on a router table, rather than the table saw.
-- Bondo Gaposis
View Luke's profile
Luke
290 posts in 2683 days
#3 posted 12-05-2013 04:35 AM
Woodsmith has a few projects with finger joints and they recommend making a small wedge shaped plug for the box bottom. Because its end grain the plug barely is visible. For higher-end type projects this may not be aesthetically pleasing.
View jordanp's profile
jordanp
1086 posts in 1936 days
#4 posted 12-05-2013 06:16 AM
You can cut a stop dado/groove with a hand saw/stair saw, by cutting in two places along the grain defining your dado width then paring out the waste with a chisel. Define the stopping point with a chisel cut before you start sawing.
You can do the same thing with a plough plane and marking the stoping point with a chisel cut.
The groove will typically be more shallow by the chisel cut/stop, so you will probably need to do some additional paring there to get a uniformed depth.
-- J. Palmer Woodworks - Rockwall TX -I woke up this morning thinking “man, I really hope someone posted some soul scarring sh*t on LJs today.” -- - Billy
jordanp
#5 posted 12-05-2013 06:21 AM
Any almost forgot
Mark your saw lines with a marking gauge, then on the waste side of the line take a marking knife and cut down the line giving you a nice V shaped grove to rest the saw blade in. A gents saw or dovetail saw does well with this task.
View Jeremy Greiner's profile
Jeremy Greiner
568 posts in 2768 days
#6 posted 12-05-2013 07:21 AM
View bannerpond1's profile
bannerpond1
397 posts in 1894 days
#7 posted 12-06-2013 12:10 AM
Like bondogaposis said, stop dadoes on the router table. Forget sawing through the finger and putting in a plug.
-- --Dale Page
View gfadvm's profile
gfadvm
14940 posts in 2686 days
#8 posted 12-06-2013 01:50 AM
I use stopped dados done on the router table. Those solid carbide spiral straight bits are nice for these.
