Forum topic by Furnitude | posted 12-04-2013 09:50 PM | 1720 views | 1 time favorited | 17 replies | ![]() |
One thing that wastes a lot of my time and causes a bit too much anxiety is how to start breaking down lumber to make parts for a project. For example, I have several wide pieces of 8/4 maple that i’m going to use for cutting boards. I start worrying that if I rough cut them the wrong way, I might not have the right pieces in the right sizes. It’s probably textbook ADD. So here’s my question, faced with a stack of lumber and a project that involves several parts that are different in size, how do you begin? Do you write a list and check them off as you go? (I do that sometimes.) Do you start with the larger pieces and work down to the smaller ones to make sure you’ve got stock big enough? I worry about this too much, but it seriously causes me to waste a lot of time sitting there looking at it. -- Mitch, http://furnitude.blogspot.com Also blog at http://www.craftsy.com/blog/author/mitch-roberson/ |
17 replies so far
#1 posted 12-04-2013 10:08 PM |
Chalk out your cuts. Cut the longest first. Buy more than you need. |
#2 posted 12-04-2013 10:10 PM |
make a list…check it twice. -- Steve-- http://www.urbanexteriors.biz |
#3 posted 12-04-2013 10:14 PM |
If I’m cutting a whole bunch of parts at once rather than on a case-by-case basis, I make a list of parts and label them with letters. Each part gets a letter on both sides and the list gets a tally mark. I’m still pretty bad about estimating the amount of stock I need though when counting waste. -- The quality of one's woodworking is directly related to the amount of flannel worn. |
#4 posted 12-04-2013 10:14 PM |
You are not suffering from ADD. You have Lumber Deficiency Syndrome. Tell your relatives, tell your friends. You need more lumber now! If you don’t act quickly, it will only get worse. -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#5 posted 12-04-2013 10:32 PM |
Pinto that was mean. Weren’t you ever taught not to go waving your wood in someone else’s face? I too go for the biggest most important piece first, rough cut it and then go find a board for the next biggest or important piece and work my way down the list. -- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium. |
#6 posted 12-04-2013 11:00 PM |
A lot of what I use is red oak with from a saw mill which is various widths and lengths. I make a list of the parts needed and then sort it based on thickness and width. I give each part a letter label. I then layout the boards that I think that I will need and then mark them off with chalk as to which part they are. Most of the time, I will need more boards as I look at the boards and the grain to get a good look on the parts which will be on the front. I mill to thickness all at one time so that all the boards are the same thickness. I also cut extra pieces to serve as back ups as some of the boards will warp or cup as I cut them and mill them. I also need some extra pieces as I typically will make a mistake or two. |
#7 posted 12-04-2013 11:41 PM |
Start with the rip cuts on longest pieces first that way you won’t accidentally crosscut a board to make a short piece and ruin it for later making that long part you forgot to save a long board for. -- Bondo Gaposis |
#8 posted 12-30-2013 08:32 AM |
Depending upon your project, it is worth considering pattern and grain matching. It is wonderful to have a line of drawer fronts cut from a single board. Or bookmatched cabinet doors. Or a jewelry box that displays unbroken grain around its sides. Obviously, for paint grade work all that becomes irrelevant. Make your cut lists even before you purchase your wood. If you must deal with random widths and lengths, at least you will know the parameters to require from your supplier for your widest and longest boards. Make lists. Check them twice. Fiddle around with graph paper and see how you can most efficiently, and cost effectively, get the best yield out of what you have. For larger projects, there are lumber optimization programs available for your computer. I’m pretty comfortable with a pencil (with eraser) and a tab of graph paper. Best of luck… -- “The creation continues incessantly through the media of man.” Antoni Gaudi |
#9 posted 12-30-2013 02:08 PM |
I take a list of the widths and rough board feet of lumber that is needed when I go to the mill. I add about 10% extra as insurance. Once I get the boards back to the shop, I lay them out and mark them with white blackboard chalk so I know which parts will come from which board before I make any cuts. This gives me a final chance to check for defects, grain and color matching before I break down the lumber. |
#10 posted 12-30-2013 02:50 PM |
I also use white chalk to lay out my boards, I have also of wood on hand so I can usually make very good use of my wood, any extra is just saved for next project. I know I save on wood by laying out all my pieces on wood before I make a cut. -- Bob in Montana. Kindness is the Language the blind can see and deaf can hear. - Mark Twain |
#11 posted 12-30-2013 03:35 PM |
I’ve gotten to the point where I build most items first in sketch-up and then build from there, I’m not great at SU but there have been several times during the design “idea” phase where I believe I’ve saved time and lumber from using SU. -- I've decided 1 mistake is really 2 opportunities to learn.. learn how to fix it... and learn how to not repeat it |
#12 posted 12-30-2013 04:10 PM |
So here’s my question, faced with a stack of lumber and a project that involves several parts that are different in size, how do you begin? Plan your work and then work your plan, usually involves a sketch with a cut list. Some plans have joinery details as well. This is good to visualize the product and the steps involved to get there. Do you write a list and check them off as you go? Do you start with the larger pieces and work down to the smaller ones to make sure you’ve got stock big enough? You make nice projects Mitch. I’m sure you used a plan and a cut list with the one pictured below. |
#13 posted 12-30-2013 04:13 PM |
I use a free program → MaxCut 2 Enter the sizes of your lumber and the sizes of the parts, and let it do the work. It will even print out labels if you need them |
#14 posted 12-30-2013 04:17 PM |
When it comes to end grain cutting boards, the really nice thing is that they don’t have to be all the same sizes, just the same width. But even then, not every row has to be the same as the last. Make it different – that is where my scraps go. -- David in Damascus, MD |
#15 posted 12-30-2013 04:20 PM |
John, does that program also use Imperial measurements or just Metric? -- The quality of one's woodworking is directly related to the amount of flannel worn. |
Forum | Topics |
Woodworking Skill Share
12033 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4906 |
6696 |
28067 |
CNC Woodworking
212 |
Hand Tools
5412 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2201 |
Coffee Lounge
8846 |
