Here I go for a first attempt
Forum topic by JMM_4 posted 12-04-2013 04:07 PM 1168 views 0 times favorited 15 replies Add to Favorites Watch
View JMM_4's profile
JMM_4
8 posts in 1541 days
12-04-2013 04:07 PM
Hey all,
Here is my attempt at a bench. Please provide feedback. So far I’m seeing at 1/8” gap from end to end. Looking for a Northern IL expert to take on a rookie wood guy.
Moving some skills to brewing beer to making some sweet furniture. Got the itch from purchasing a generic HF jig and want some precision.
15 replies so far
View Tedstor's profile
Tedstor
1643 posts in 2539 days
#1 posted 12-04-2013 04:18 PM
Was there supposed to be a pic attached?
View JustJoe's profile
JustJoe
1554 posts in 1944 days
#2 posted 12-04-2013 04:25 PM
It’s a magic invisible bench! Do you know how hard those are to make? And you nailed it in your first attempt. :)
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View bondogaposis's profile (online now)
bondogaposis
4608 posts in 2257 days
#3 posted 12-04-2013 04:27 PM
Yes, the invisibility cloak works amazingly well in the photo, hard to tell there is even a bench there.
-- Bondo Gaposis
JustJoe
#4 posted 12-04-2013 05:09 PM
Hey don’t be scared off – we’re just kidding you. It looks like you are having trouble posting the pics. Let us know if you need help.
JMM_4
#5 posted 12-04-2013 05:20 PM
There we go. Stupid technology….
View jordanp's profile
jordanp
1086 posts in 1847 days
#6 posted 12-04-2013 05:35 PM
it is an 1/8th inch gap between the layers of the ply wood?
Was it glued and clamped together or just screwed together?
-- J. Palmer Woodworks - Rockwall TX -I woke up this morning thinking “man, I really hope someone posted some soul scarring sh*t on LJs today.” -- - Billy
JMM_4
#7 posted 12-04-2013 06:01 PM
So two layers of CDX 3/4 ply bolted together. One 3/8 ply screwed to the top. No glue used with the idea I may want to disassemble it later. I also do not have any screws in the middle of the field. Now I’m thinking glue and countersink a couple screws in the middle.
View John Stegall's profile
John Stegall
497 posts in 3423 days
#8 posted 12-04-2013 06:09 PM
It also looks like your spacing between screws is kind of wide…but are you going to be cutting through the top layer (1/4 inch or less)? If so be sure to mark their location well.
-- jstegall
bondogaposis
#9 posted 12-04-2013 06:56 PM
I say glue with clamps and cauls, omit the screws except for a few to keep from shifting during glue up. Put the 3/8 plywood in the middle for a balanced glue up.
-- Bondo Gaposis
View crank49's profile
crank49
4029 posts in 2877 days
#10 posted 12-04-2013 07:12 PM
I built my entire bench out of plywood, 3 sheets of 3/4” AB sand ply, legs, stretchers and all.
I screwed and glued the top together. Four layers thick, topped with MDF and hardboard which are replaceable.
i put screws on 8” centers.
After using it for 3 years I wish I had removed the screws from each layer after the glue dried before adding the next layer.
Would have taken a little longer to build, because I did the entire top in one day, but then I wouldn’t have to worry about hitting a screw when drilling dog holes. Don’t ask how I know that is a problem.
One other very important consideration, which I did take care of, is to be absolutely sure the top is level and not twisted or bowed. If you glue it up with a twist in it, there is no way to un-twist it after the glue sets.
JMM_4
#11 posted 12-04-2013 07:18 PM
I see. This is great input. Now let me share an idea. I’m going to use the bench for face frames and pocket screw projects. I was contemplating throwing some linoluem tiles on the surface. Makes for a smooth finish and helps hold the wood in place. Thoughts?
bondogaposis
#12 posted 12-04-2013 07:55 PM
The tiles might work but Formica would be better.
-- Bondo Gaposis
View pintodeluxe's profile
pintodeluxe
5568 posts in 2719 days
#13 posted 12-04-2013 07:58 PM
That will be a useful table for assembly and glueups.
JMM_4
#14 posted 12-04-2013 09:02 PM
I’m going to eye up a couple tiles this evening and give it a go. Nice thing about peel and stick. If I don’t like it I can toss it.
JMM_4
#15 posted 12-05-2013 02:18 AM
Attempt at tiles? Fail.
Advice taken: a couple more screws countersunk into the center field. Now the surface is rock solid and glass smooth.
Next is the addition of a power strip mounted on the bottom of the surface. That way I won’t accidentally run into a plug or three. Then thinking of additional storage. A nice couple hooks for a level and clamps.
Thanks for the input all. Very helpful.
