Hinge on Cedar Chest
Forum topic by CharlesA posted 12-04-2013 03:36 AM 6827 views 0 times favorited 13 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3319 posts in 1793 days
12-04-2013 03:36 AM
So, I’m about done with a cedar chest (out of cedar) that looks like this one:
I just need to attach the trim around the top of the box, then install lid. I had a great idea to use the Rockler torsion hinge, http://www.rockler.com/lid-stay-torsion-hinge-lid-support-rustic-bronze.
I wasn’t thinking, though, and just realized that the torsion hinge must fit over 3/4 board. I have two options. Go with a standard hinge and a flap stay, or “mortise” the trim so the torsion hinge will fit.
Your thoughts?
13 replies so far
View pintodeluxe's profile
pintodeluxe
5654 posts in 2808 days
#1 posted 12-04-2013 04:37 AM
I think I might use different hinges due to the trim on that chest.
You might have to go with hinges and a separate soft-close strut.
View mandatory66's profile
mandatory66
202 posts in 2126 days
#2 posted 12-04-2013 05:44 AM
I ran into the same problem on my chest. My hinge design was the same but without the torsion feature. They were also thinner. I mortised the trim (about 1/8 inch wide ) to allow them to slip in. Worked well and with a tight mortise fit no one noticed, also used a separate lid strut.
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2350 days
#3 posted 12-04-2013 06:44 AM
piano hinges, a bit tough to install, but worth it.
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
CharlesA
#4 posted 12-04-2013 07:03 AM
Why the piano hinge?
TCCcabinetmaker
#5 posted 12-04-2013 07:18 AM
Well when you say cedar I am guessing you mean aromatic, the brass just gives it a feel, and they are very hard to bow or break under normal circumstances. it’s just a really dependable sure fire hinge in the chest world. With a regular style of hinge they can be torqued one way or the other causing the screws to strip or wood to crack, so on and so forth. That’s why piano hinges are a main stay in chests, where people may sit on them at some point. They are also easy to fit, but the size that’s longer but closest to what you need, mark the length, put on some safety glasses, and cut. Also let the drops from them sit a minute before you go to pick them up, they’ll be really hot.
View MJCD's profile
MJCD
541 posts in 2366 days
#6 posted 12-04-2013 12:57 PM
An un-formed thought:
Could you reverse the torsion hinge, such that the ‘cupping’ portion is affixed to the top, while the portion typically screwed to the top is, in-fact, screwed to the base? Also, for my blanket chest, I added a spacer on the top portion to allow larger screws than the ones provided (see my Projects) – the Rockler site has user comments that the provided screws were too small for the … torsion.
MJCD
-- Lead By Example; Make a Difference
View bigblockyeti's profile
bigblockyeti
5112 posts in 1716 days
#7 posted 12-04-2013 01:29 PM
I use piano hinges all the time on chests and small boxes. Aside from the above mentioned mechanical benefits, they can be cut to length to fit almost any project, are available in different materials and sizes.
CharlesA
#8 posted 12-04-2013 04:51 PM
Thanks for all the help. Two follow up questions:
1) do you just attach the piano hinge or do you make a mortise? I gather no mortise.
2) Any suggestions on a specific soft close strut?
View Lee Barker's profile
Lee Barker
2170 posts in 2845 days
#9 posted 12-04-2013 07:06 PM
Shameless commerce: I just listed some sidemount chest hinges for sale. It’s in the “woodworking trade and swap” forum.
They would be one solution to this beautiful example.
Kindly,
CharlesA
#10 posted 12-04-2013 07:11 PM
Thanks, Lee. Since the trim piece extends inward and outward, I assume I’d have to mount a block on the sides of the box to install those, right?
Lee Barker
#11 posted 12-04-2013 07:15 PM
Correct, Charles. And I’d want to be sure they wouldn’t interfere with those interior cleats on the lid.
Kindly,
Lee Barker
#12 posted 12-04-2013 08:11 PM
On second observation, Charles, I don’t think they’ll work on that design. The cleat on the inside back would prevent the top from being able to be flush with the back. Wouldn’t look good. But thanks for considering them. For them to properly work the back wall of the chest would have to be the same thickness as the top.
Kindly,
117090 posts in 3572 days
#13 posted 12-04-2013 08:31 PM
I’m with TCC paino hinges plus lid suports.
http://www.rockler.com/search/go?w=toy%20box%20lid%20support
