Cons of mixing softwoods with hardwoods
Forum topic by siavosh posted 12-03-2013 03:15 AM 2725 views 0 times favorited 7 replies Add to Favorites Watch
View siavosh's profile
siavosh
674 posts in 1865 days
12-03-2013 03:15 AM
Are there any special considerations in building woodworking pieces (I’m thinking of a dovetailed box) that mixes both softwoods and hardwoods? I’m thinking of making a box out of combination of walnut, cherry, alaskan cedar. Most pieces I’ve seen are either all hardwood or all softwood. Thanks.
-- http://woodspotting.com/ -- Discover the most interesting woodworking blogs from around the world
7 replies so far
View nwbusa's profile
nwbusa
1021 posts in 2280 days
#1 posted 12-03-2013 03:26 AM
Not really, other than the different seasonal expansion/contraction rates of the various species (not specific to mixing hardwoods and softwoods). Of course, softwoods are generally less durable than hardwoods, which might be a consideration if you were building something that could see a lot of surface wear. Probably not a big deal for a box.
-- John, BC, Canada
View shampeon's profile
shampeon
1775 posts in 2177 days
#2 posted 12-03-2013 03:52 AM
Go for it. A box isn’t big enough to make seasonal expansion a big deal. If I were doing dovetails with those woods, I’d make the cedar the pins, as they can compress into the walnut or cherry tails to fill up space for a tight dovetail.
View bondogaposis's profile
bondogaposis
4717 posts in 2345 days
#3 posted 12-03-2013 04:34 AM
There is no good reason you can’t do this. When dovetailing softwoods you notice it is a little mushy compared to hardwood, it’ll compress a bit and make some tight joints as Shamp suggests.
-- Bondo Gaposis
View Rick's profile
Rick
9591 posts in 3026 days
#4 posted 12-03-2013 05:43 AM
None Whatsoever! Just DO IT!!
-- LIFE is what happens when you're planning on doing Other Things!
siavosh
#5 posted 12-03-2013 06:51 AM
Thanks! The mixed wood project will continue…
View MrRon's profile
MrRon
4758 posts in 3237 days
#6 posted 12-04-2013 05:15 PM
I would arrange it so that the pins are hardwood and the tails were softwood. Hardwood pins would be stronger.
View Lee Barker's profile
Lee Barker
2170 posts in 2844 days
#7 posted 12-04-2013 05:37 PM
I’ll add my voice to the “go for it” crowd and append this:
I think there are combinations that work and combinations that don’t. As a woodworker, I wouldn’t mix softwoods with hardwoods, but I allow that, artistically, it can be exactly the right thing to do.
To my eye, color is more important than label. Mix a light colored wood with walnut? Maple is just too white. Alder, however, has the right amount of warmth. Walnut dowels on a cherry piece? Doesn’t seem to work for me, but ebonize something and put it there and it makes the cherry pop with joy.
Kindly,
