wood finishing
Forum topic by pete69 posted 12-02-2013 02:40 PM 1072 views 0 times favorited 13 replies Add to Favorites Watch
View pete69's profile
pete69
42 posts in 1961 days
12-02-2013 02:40 PM
good morning everyone, hope all is well. I have some wood slams that i am making into coat racks and need to know what is the best way to finish them? i would like them to have like that glossy (glass) finish to them. thanks for the help. regards
13 replies so far
View Purrmaster's profile
Purrmaster
915 posts in 1965 days
#1 posted 12-02-2013 02:51 PM
If you want a glossy/glass finish you may have to eventually rub out the finish. Which could be hard with a coat rack.
I would say the easiest thing would a gloss sheen wiping varnish. Wipe on polyurethane, for example. I think Waterlox has a gloss version of their varnish. You could also get some spray cans of gloss lacquer and spray that on.
pete69
#2 posted 12-02-2013 02:54 PM
ok thank you. i will give it a shot. how many coats of polyurethane do i put on? thanks again.
View Cedar Furniture Lodge 's profile
815 posts in 2145 days
#3 posted 12-02-2013 03:16 PM
I would put at least 5 coats of poly, that will give you the look your after. I use Minwax clear gloss polyurethane.
That’s the best I can offer you, good luck.
-- "The Cedar King"
pete69
#4 posted 12-02-2013 03:21 PM
awesome thank you very much.
View jumbojack's profile
jumbojack
1673 posts in 2497 days
#5 posted 12-02-2013 04:13 PM
Pete;
A couple of things before you get started. Sand your rack to 150, maybe 180. Get rid of the dust by wiping with a rag and or compressed air. If you have exposed end grain and want it to look similar to the face grain sand it to say 220. Now comes the easy part. First coat should be a thin one. Dont rush this part of finishing. Let the first coat dry! If you use lacquer, depending on the environment, you can get several coats on in one day. Check the label for drying times. Apply another coat, this one can be a little thicker but dont get crazy. LET IT DRY. Get some 300-400 grit sandpaper and lightly sand. You want a really smooth finish. You can feel when you are getting close, not as much drag. Flip the sandpaper often, it should be getting loaded with finish. Dont sand too much, you are just knocking down the high spots. Feel for smoothness with your off hand. When you are satisfied with the feel, wipe down throughly and apply another coat. Let this coat dry. Like it? If not one more thin coat can be applied. I like a softer sheen on most of my pieces, but to rub out to a gloss, very light sanding with 1000-1500 or even a plain paper bag, like from the grocery, will really bring out the gloss. Now some paste wax. I use Johnson but there are plenty of quality paste waxes out there. Apply the wax, wait, say 10 mins and vigorously rub with a rag, tee shirt, towel whatever you’ve got.
Dont forget to take a pic and post it up here. I for one would love to see the finished piece.
pete69
#6 posted 12-02-2013 04:38 PM
wow, thank you so much. i cant wait to get started. i will post pictures as soon as i get done.
View Clint Searl's profile
Clint Searl
1533 posts in 2234 days
#7 posted 12-02-2013 10:48 PM
Make it simple and foolproof. Just hit it with spraycan gloss lacquer as many coats as make you happy.
pete69
#8 posted 12-13-2013 02:09 PM
hey everyone, hope all is well. ok so my finish for the coat rack is just about done and i am trying to figure a good way to hang it? any idea would be great.
116807 posts in 3450 days
#9 posted 12-13-2013 02:22 PM
pete69
#10 posted 12-13-2013 02:38 PM
a1Jim thank you very much, i like the first one, think they will make it look cleaner. thanks again, best regards
pete69
#11 posted 12-16-2013 09:30 PM
Thank you all for all your help. here it is!!! i think it came out ok.
#12 posted 12-16-2013 09:31 PM
Looks great Pete,nice work.
pete69
#13 posted 12-16-2013 09:32 PM
thank you Jim.
