Bandsaw problem
Forum topic by milt45 posted 12-02-2013 01:47 PM 762 views 0 times favorited 5 replies Add to Favorites Watch
View milt45's profile
milt45
1 post in 1726 days
12-02-2013 01:47 PM
I have a Jet 12 inch bandsaw with a 1/2 inch blade. I’m trying to make a bandsaw box with drawers like I’ve seen done on You Tube. I can make 6 inch deep cuts, so I’m using a block of wood about 5 3/4×5. The problem is after making the first cut the blade did not cut straight, it bowed or curved. I checked the blade tension and it appeared to be set correctly.
Any suggestions?
Milton or milt45
5 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2776 days
#1 posted 12-03-2013 02:36 AM
You need a much narrower blade to make bandsaw boxes. I use 1/8”-1/4” blades for cutting bandsaw boxes. The narrower the blade, the tighter the radius you can cut.
View distrbd's profile
distrbd
2252 posts in 2532 days
#2 posted 12-03-2013 02:46 AM
+1 gfadvm,I also think your blade is dull.
-- Ken from Ontario, Canada
View jumbojack's profile
jumbojack
1678 posts in 2710 days
#3 posted 12-03-2013 02:51 AM
Quality blades = quality cuts
Junk blades…..............you get the idea
View Surfside's profile
Surfside
3389 posts in 2259 days
#4 posted 12-03-2013 10:07 PM
Switch to a new blade…
-- "someone has to be wounded for others to be saved, someone has to sacrifice for others to feel happiness, someone has to die so others could live"
View coachmancuso's profile
coachmancuso
259 posts in 2017 days
#5 posted 12-04-2013 12:12 AM
I would say switch to a new blade and I use a 1/4” blade for my band saw boxes . A 1/2” blade is to wide to make the cuts you need for bandsaw boxes. When you use a blade like that and try to make the sharp cuts for a band saw box you dull the blade a lot faster b3ecause it is binding instead of a smooth cut
-- Coach Mancuso
