How to flatten cutting board?
Forum topic by coletrain posted 351 days ago 539 views 2 times favorited 20 replies Add to Favorites Watch
View coletrain's profile
coletrain
20 posts in 498 days
351 days ago
Hey guys,
I am making cutting boards for christmas presents this year and have run into a problem. The pattern i am using is the one off Woodwhisperer and I have finished the first glue up. Now that the blocks are glued together some of them are higher than others. I need to plane them down but dont have a planer. I do have a 6” craftsman jointer but the cutting board is ~12” wide. Im not familiar with hand planers although I do have a few but I do have a random orbital sander. Could that get the surface level enough to not have any gaps in the end grain for the final glue up??
View JerryS's profile
JerryS
73 posts in 507 days
351 days ago
Sounds like a good excuse for learning how to use those hand planes . Test it out on some scrap pieces .
View miles125's profile (online now)
miles125
1431 posts in 902 days
351 days ago
Or you could take em by a local cabinet shop with a wide belt sander!
View bentlyj's profile (online now)
bentlyj
790 posts in 367 days
351 days ago
Bring them by :)
You could use your sander, just put on some rough paper and work your way up. I would start with 80 grit, depending on how much you need to take down. You could plane them down close enough to use your sander, that may take some sanding work out of it. I think you would be surprised how well you could get them with a plane.
View lew's profile
lew
4495 posts in 652 days
351 days ago
Someone here posted a jig that uses a router to do exactly what you want. Sorry I can’t remember who it was but a search should reveal it.
View Steelmum's profile
Steelmum
347 posts in 859 days
351 days ago
GaryK did the jig for the router. This is the link.
http://lumberjocks.com/topics/1992
-- Berta in NC
View marcb's profile
marcb
704 posts in 570 days
351 days ago
I did something similar to GaryK
Didn’t take long to whip together a jig. I made the cross pieces that the router runs on sized for my router plate so I just popped the router table router out and used that.
View PetVet's profile
PetVet
233 posts in 384 days
351 days ago
I have made several of those this year, but I have a thickness drum sander to even them out. If you use a hand plane, work towards the center so you don’t get split out on the edges. The ros with even a coarser grit than 80 would be the way to go. For your second glue up build a right angle jig with a plywood bottom just an half inch shorter than the dimensions of your finished cutting board, using scraps on two edges to form the right angle. Wax it, or cover with wax paper during the second glue up. You want the corners of the squares to be dead on as you clamp, so pay close attention to that. Also, clamp a board on top before applying a lot of side pressure with your clamps to keep the cutting board flat and decrease the amount of sanding you will have to do after the glue up. Good luck!!
-- Rich in Richmond
View dennis mitchell's profile (online now)
dennis mitchell
3790 posts in 1211 days
351 days ago
...how bout a good ol fashoned beltsander.
View ShopMonkey's profile
ShopMonkey
24 posts in 353 days
351 days ago
I would hone those hand plane irons with a wetstone and then give it a shot. Prolly wanna use a block plane though, if you got one. Drum sanders work pretty good if you have access to one. Pretty high priced machine.
-- I like trees ...... as long as their by the board foot.
lazyfiremaninTN
528 posts in 849 days
351 days ago
As stupid and maybe some would say dangerous, but I run mine thru the planer. I take tiny bites off and keep fliping them over back and forth. So far I have done about 20 different sized boards and they have all come out flat and level.
I only do long grain this way, have not made any end grain yet.
View jockmike2's profile
7328 posts in 1143 days
351 days ago
That someone Lew is talking about is Garyk. He used a long piece of plywood about 2 foot wide, with a 2×4 up right on both sides I think. Then had his router on a platform on wheel that he could run up and down the board he had secured inside the rails. That is not a good explanation of it. I’m sure if you sent Gary a pm he would show it to you..
-- Mike. mwurm13@yahoo.com
7662 posts in 1115 days
351 days ago
Like Dennis, I use a belt sander. Messy, but it works.
coletrain
351 days ago
Wow everyone, Thanks for all the replies.
Brett
View spaids's profile
spaids
460 posts in 590 days
351 days ago
I used my planer on an end grain cutting board. You can get a bit of chip out like that so i rounded over the edges a little bit and it help a lot. So is it really dangerous?
-- Wipe the blood stains from your blade before coming in.
View PeteMoss's profile
PeteMoss
61 posts in 367 days
351 days ago
I use the planer on the end grain also. Only take somewhere in the 1/128 to 1/64 range of a cut, about an eighth of a handle turn. Works pretty well, but definately seems to be hard on the blades. I also cut a chamfer on the trailing edge to eliminate chipout. It actually works very well on the hard maple, and cherry, but on oak it tends to tearout the endgrain over the whole face of the board, then you have to sand it down for an extended time.
-- PeteMoss
teenagewoodworker
2482 posts in 665 days
351 days ago
either a router jig, a widebelt sander from a cabinet shop, or a hand plane. don’t use and ros because it won’t get it flat it will only get it flush and that can cause problems later on. hand planes are too hard to use. you should have no problem.
View Simon's profile
Simon
2 posts in 442 days
351 days ago
Having just come in from making end grain chopping boards for Christmas (purpleheart and hard maple) here is my take on it. Last night I used a belt sander and 80 grit followed by 150 grit, my guess is I spent nearly an hour sanding the first board, it was a bit of an epic (and it was pretty flat and accurate!). I searched the web today for folks who may have used their P/T on end grain, there seemed to be folks doing it, so I tried taking very very small cuts using an industrial strength Wadkin P/T. I followed this with same sanding regime but was done in 15 mins. I then cut a small strip (1/16th) off the trailing edge where the P/T had caused chipping.
So I think you will really struggle with a small sander, even with a big Makita belt sander it may be time consuming, you might want to seek out someone who can run it through a P/T for you and then clean up the trailing edge or a big drum sander
hth Simon
View DRdeveloper's profile
DRdeveloper
23 posts in 362 days
349 days ago
I’ve been running mine through the planer… not sure why that is dangerous… when it’s all glued together, it goes through nice and smooth.
-- Mark, Dominican Republic
coletrain
348 days ago
Well, i went to the hardwood supplier that I get my stock from and they planed it down for free! Some good guys there.
Brett
View woodyoda's profile
woodyoda
121 posts in 354 days
348 days ago
Here’s a cheap easy way…...take two pipes taller than your project wood, duct tape to galvanized steel pipes on top so they are above your project.make it so your router can be run over your project, it’ll do a couple of inches….move your pipes over and do a few more inches, until you’ve done your whole board…..then sand it off. As long as your on a flat surface it will work fine….just make sure your cutter is chucked up so that the cutting edge doesn’t hit the pipe, just the round part of your bit. shouldn’t take long at all.
good luck Steven
