dining table with company boards
Forum topic by jdh122 posted 12-01-2013 07:01 PM 2908 views 0 times favorited 6 replies Add to Favorites Watch
View jdh122's profile
991 posts in 2747 days
12-01-2013 07:01 PM
I’m looking for advice or plans for making a dining table with company boards. I can’t quite get my head around how they work (slides that disappear into the apron and under the table, and the extensions/table leaves have short battens too, it seems). I looked through finewoodworking magazine index and also popularwoodworking and couldn’t come up with anything.
Thanks for any advice.
-- Jeremy, in the Acadian forests
View AandCstyle's profile
2997 posts in 2186 days
#1 posted 12-02-2013 12:26 AM
Jeremy, is this what you are seeking? If so, it was in FWW #7 IIRC by Tage Frid. If it is what you want to do, I will be happy to try to answer any questions you may have. HTH
-- Art
#2 posted 12-03-2013 06:10 PM
That sure looks interesting – quite a it more complicated than what I had in mind (simply extensions that get added onto the ends of the table). But intriguing. When I get a minute I’ll take a look at the article you mention and I may get back to you with questions.
View pintodeluxe's profile
5587 posts in 2742 days
#3 posted 12-03-2013 06:40 PM
I used equalizer extension slides. You pull one side, and both sides open equally. I used folding aprons on the leaves, so they would fit inside the table for storage.
Here is the project page with more information.
Good luck.
#4 posted 12-12-2013 02:12 PM
Thanks pintodeluxe. This looks interesting too, but also a bit more complicated than I had in mind. Beautiful table, though…
View CharlesNeil's profile
2342 posts in 3799 days
#5 posted 12-12-2013 03:50 PM
I have built numerous of them , I use a simple tongue set up on the company boards, and a notch in the end aprons, works well. I don’t have any plans per say but would imagine I could walk you throught it. Here is just a few of the tables I have made and unfortunately a company board one is not in there.. but they are not difficult .
The biggest issue is you cant get much past 16” on the company board unless you add a center leg .Built one that was 12’ as the primary tabl;e and 2 , 4 ft company boards with a slide on center leg. It looked like a bowling alley .. but was fun to do.
View Loren's profile
10079 posts in 3577 days
#6 posted 12-12-2013 04:38 PM
The extensions on this old table are mounted on sliding boards about 1.5” deep
and tapered as I hope you can see. The aprons are notched and guide
blocks attached to the underside of the center of the table keep them
running straight. They are stopped by a protruding dowel which bangs
up against the back of the apron. There is a gap about 1/4” wide if you
pull them out all the way, so you pull them out and the upper part
falls down with a bang, then you push the extensions in.
