4x4 coffee table
Forum topic by DORNER posted 12-01-2013 05:56 PM 6856 views 0 times favorited 6 replies Add to Favorites Watch
View DORNER's profile
DORNER
4 posts in 1686 days
12-01-2013 05:56 PM
https://s3.amazonaws.com/vs-lumberjocks.com/mx52m3s.jpg
I have been trying to figure out how to make this coffee table. I am having trouble figuring out how the the cubes are attached to each other or are they solid with slots cut in them.
Is there anyone who has seen this design and could help me out?
Nathan
View MrRon's profile
MrRon
4757 posts in 3237 days
#1 posted 12-01-2013 06:23 PM
Definitely not the latter. That would be a huge piece of wood. That table looks unique, but I wouldn’t want to have to keep it clean.
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1721 days
#2 posted 12-01-2013 06:30 PM
DORNER
#3 posted 12-02-2013 02:59 AM
Thanks i could not find any info on that pic that i had. I found that pic on The Chive and thought it looked pretty cool. But I don’t think that I will be trying the magnets. I would rather it be more rigid than that. I was thinking maybe 3/4” threaded rod and use washers and nuts to keep the spacing.
GOOD LUCK TO ALL
#4 posted 12-02-2013 03:12 AM
You could glue all the blocks together,
then run dado’s as deep as you can through the seams to give you the look.
or Rout the grooves in several passes?
View DeltaDaddy's profile
DeltaDaddy
52 posts in 1647 days
#5 posted 12-02-2013 03:35 AM
I would cut all the cubes then on a drill press drill a hole at least 1” deep centered on the block to accept a dowel. same on all sides that have a block next to it. cut pieces of dowel long enough to join the blocks together with the proper gap between them. Or if you have a mortiser you can have square stock connecting the blocks. make sure to apply finish to the blocks before assembly.
-- Take it apart to see how it works
View Pezking7p's profile
Pezking7p
3217 posts in 1645 days
#6 posted 12-02-2013 03:47 AM
I think deltadaddy has it right. If you look at the blocks, some of them are skewed a bit, which I think you would only get if you were using dowels to hold them together.
It would be very cool if you ripped the pieces for each face of the table from the same board.
-- -Dan
