Correct Lateral Adjust Lever for 605 1/2 BED ROCK plane??
« back to Hand Tools forum
Forum topic by hhhopks posted 12-01-2013 05:03 PM 2723 views 0 times favorited 9 replies Add to Favorites Watch
View hhhopks's profile
hhhopks
650 posts in 2247 days
12-01-2013 05:03 PM
Topic tags/keywords: lateral adjust lever stanley bed rock 605-12 hand plane question plane
I would like to consult the hand plane gods on LJ.
Please look at the pictures below. Does this lateral adjust lever belongs to the Stanley 605-1/5 Bed Rock hand plane?
It has Patent Date of Feb 3 91 on it and it is all one piece.
Since the lateral lever is bent and a bit loose, I am debating if I should replace it.
If the lever doesn’t belong to the plane, I will replace it with a “STANLEY” lever.
Who’s plane would have a patent date on a lateral adjust lever, if it is not Stanley?
-- I'll be a woodworker when I grow up. HHHOPKS
9 replies so far
View JustJoe's profile
JustJoe
1554 posts in 1908 days
#1 posted 12-01-2013 05:08 PM
If it’s 1891 then Sargent had a lateral with that patent date.
http://www.datamp.org/patents/displayPatent.php?pn=445792&id=8930
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
JustJoe
#2 posted 12-01-2013 05:10 PM
Like a gruesome train wreck I had to circle back for another look. It’s just the wrong lateral right, someone lost one and slapped on any old replacement they could find? The frog is correct right?
View ShaneA's profile
ShaneA
6877 posts in 2468 days
#3 posted 12-01-2013 06:02 PM
Frog looks correct. Carefully knock the existing incorrect lat adj lever out, and replace w/correct vintage. Should not be too difficult. Just remember to support the frog if/when any blows are struck. Break the frog, and it will be spendy fix.
View poopiekat's profile
poopiekat
4322 posts in 3604 days
#4 posted 12-01-2013 06:37 PM
Hey, what kind of screws are those, holding the frog to the sole?
View sikrap's profile
sikrap
1121 posts in 3228 days
#5 posted 12-01-2013 06:52 PM
Those aren’t screws, they’re pins. There are screws on either side of the adjuster screw for loosening the frog. This design allows you to adjust the frog without removing the lever cap/ iron. Probably the biggest reason flat-sided Bedrocks are so popular.
To the OP- I don’t think that’s a Stanley lateral adjuster. I suspect the original came off and someone “fixed” it from a donor plane.
-- Dave, Colonie, NY
View 69BBNova's profile
69BBNova
341 posts in 2086 days
#6 posted 12-01-2013 07:07 PM
I have a spare lateral lever if this one turns out to be correct for your plane…
Its a No.5 that I’m not going to use because it has a crack on the toe…
The only markings on the bed is No. 5 on the very front of the toe, the lever cap has an S cast on the underside and the frog has a cast S on the very bottom of the underside…
If it turns out to be right let me know and I’ll get an envelope and send it out to you.
Just looked again…on the bed there is an O or 0 plus an S cast inside the raised portion for the rear handle (tote?).
4820 posts in 2363 days
#7 posted 12-01-2013 07:39 PM
The lever on my 605 looks exactly like the one 69bbnova photographed.
View Don W's profile (online now)
Don W
18556 posts in 2437 days
#8 posted 12-01-2013 07:43 PM
A bedrock with a Sargent lateral. How about that?
hhhopks
#9 posted 12-01-2013 10:36 PM
Thanks for the input folks.
I’ll replace the lever. I knew it didn’t look right. It is nice that the LJ gods could validate my concern.
It should be easy by following this LJ forum which I came across with my posting this morning.
