Wood won't stop growing!
Forum topic by 1goldsniper posted 12-01-2013 02:04 AM 1064 views 0 times favorited 3 replies Add to Favorites Watch
View 1goldsniper's profile
1goldsniper
7 posts in 1925 days
12-01-2013 02:04 AM
I made a couple of the 30 degree/walnut,purple heart,maple cutting board that has the 3 dimensional effect. No problem and it turned out good. Problem is wood will not stop growing it appears. After coating with olive oil multi coats. after a month or two the walnut boarder on one will grow length wise about a thirty/second of and inch. On the other most of the blocks are about a paper dollar thickness thicker. Blocks are not end grain but straight grain. What am I doing wrong?
3 replies so far
View richardwootton's profile
richardwootton
1699 posts in 1862 days
#1 posted 12-01-2013 02:28 AM
I really want to say, “that’s what she said,” but that doesn’t answer your question. I’m guessing it has to do with the difference with which each of the types of woods moves with moisture. Different species will move more than others as the moisture content changes.
-- Richard, Hot Springs, Ar -- Galoot In Training
View tefinn's profile
tefinn
1222 posts in 2344 days
#2 posted 12-01-2013 03:02 AM
i agree with Richard. Your wood is moving as it dries or absorbs moisture from the air.
I noticed you say you coated with olive oil. Why? Olive oil and other vegetable oils go rancid and shouldn’t be used. Use mineral oil (either from the drug store or food grade if you can get it) or one of the finishes made for cutting boards and salad bowls.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View bondogaposis's profile
bondogaposis
4611 posts in 2258 days
#3 posted 12-01-2013 05:14 AM
Without seeing a picture I can’t really say specifically, but generally these problems are caused by wood movement. The problem stems from the fact that wood does not move equally in all directions but rather differentially in the 3 planes of reference according to which position the board occupied in the tree from which it came. The 3 planes are radial, tangential and longitudinal. Problems most often occur when trying to confine pieces of wood in a frame. Wood movement in the longitudinal direction is so minute as to be negligible, therefore the inner pieces are shrinking and swelling with the ambient humidity but the frame is not changing in length, if the corners are mitered they will generally open over time.
-- Bondo Gaposis
