Quick Bandsaw blade change?
Forum topic by CharlesA posted 11-30-2013 05:39 PM 1167 views 0 times favorited 15 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3305 posts in 1707 days
11-30-2013 05:39 PM
Topic tags/keywords: question bandsaw
I’m sure the answer is no, and that I should stop whining, but I’ll ask anyway.
For a number of reasons I keep a 1/2” blade in my bandsaw much of the time, but I need to change the blade for a curved cut today. Changing the blade, with requisite changes in the bearings, etc., is a pain for such a short job.
Have you learned anything from your experience on how to make a quicker blade change?
15 replies so far
View MedicKen's profile
MedicKen
1610 posts in 3371 days
#1 posted 11-30-2013 05:46 PM
Buy a second saw
View jumbojack's profile
jumbojack
1673 posts in 2533 days
#2 posted 11-30-2013 06:19 PM
I feel your whine.
View Loren's profile
9983 posts in 3557 days
#3 posted 11-30-2013 06:23 PM
+1 MedicKen.
On some saws the blade comes out a slot in the front
of the table and I have found it easier to change blades
on these saws than the ones with the slot to the side.
View pintodeluxe's profile
pintodeluxe
5569 posts in 2723 days
#4 posted 11-30-2013 07:36 PM
Like you, most of my cuts are made with a 1/2” 3 tpi blade. It resaws well, and will cut a gentle curve.
For tighter radius cuts, I decide if it’s worth the time to change blades. If not, I just grab the jigsaw.
Sometimes you can get away with cutting a curve with a 1/2” or 3/8” blade, as long as you make relief cuts.
CharlesA
#5 posted 11-30-2013 07:36 PM
I went ahead and out the 1/4 blade on, and since I had spent so much time working with it on last blade change, it actually went pretty quickly.
CharlesA
#6 posted 11-30-2013 07:48 PM
I thought about the jig saw, but I was cutting 2” square legs. TS blades are so much easier.
View tomd's profile
tomd
2127 posts in 3680 days
#7 posted 11-30-2013 08:47 PM
Go to You Tube and watch bandsaw setup by Alex Snoggrass.
-- Tom D
CharlesA
#8 posted 11-30-2013 08:57 PM
I have—that’s why I am as good as I am at it ;-).
View distrbd's profile
distrbd
2252 posts in 2356 days
#9 posted 11-30-2013 11:37 PM
I find it easier to change blades if I remove the table.
-- Ken from Ontario, Canada
View Loco's profile
Loco
210 posts in 1659 days
#10 posted 12-01-2013 09:45 PM
Take all the guides off and throw them in a lake. Buy a Carter stabilizer.
-- What day is it ? No matter. Ummmm What month is it ? No moron. I paid for a 2 x 6. That means Two inches by six inches. I want the rest of my wood.
View ChuckV's profile
ChuckV
3097 posts in 3436 days
#11 posted 12-01-2013 10:16 PM
I change blades fairly often. I try to resist the temptation to use my Woodslicer resaw blade for lots of other cuts. I have found that I can do the change much faster after a few years of practice.
I no longer worry too much about the tension. I have learned what the blade should sound like when I give it a pluck. For the thrust and side bearings, I spin one of the wheels, turn the bearing in until it just touches the blade (starts spinning) and then turn it out until it stops touching (stops spinning). This is also a good test of the front-to-back positioning of the side bearings. If they are too far forward, there is a distinctive sound as the teeth gently hit the bearing.
My saw has a quick-release de-tensioner. That probably helps too.
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
View Tennessee's profile
Tennessee
2755 posts in 2424 days
#12 posted 12-01-2013 10:30 PM
Have to be honest…use my big Grizzly mainly for resawing with a 1\2” blade or wider, and have a much cheaper PC from Lowes that normally runs a 1\8” or 1\4”. Over time, the PC pays for itself. Only restriction would be needing a 1\4” or less blade with a throat larger than 14”, which almost never happens.
View Hawaiilad's profile
Hawaiilad
3136 posts in 2930 days
#13 posted 12-01-2013 10:48 PM
I also change out blades often…I like building Band saw boxes, and yes it can be a pain. I have old Harbor Freight BS that I am adding a riser kit from Delta and a new Carter stabilizer to in hopes I can keep the 1/2” wood slicer on it and use the Delta for finer blades.
-- Larry in Hawaii,
View poospleasures's profile
poospleasures
686 posts in 2393 days
#14 posted 12-02-2013 01:17 AM
I have a 37 year old craftsman bandsaw that I paid 65.00 for then put 85.00 carter stabilizer guide on it. It does all my curved cutting with either a 3/16 or 1/4” blade. Keep the woodslicer on my big ShopFox. Sure does speed up the processes and keeps me from cussing.
-- I,ve had amnesia for as long as I can remember. Vernon
CharlesA
#15 posted 12-02-2013 02:09 AM
Okay, I’ll bite. I have a newer craftsman 12” and I’ve set it up pretty carefully and replaced the side bearings. What do I get by adding carter stabilizer?
