Transtint and Arm-R-Seal
Forum topic by rrdesigns posted 11-28-2013 01:19 AM 2052 views 0 times favorited 6 replies Add to Favorites Watch
View rrdesigns's profile
rrdesigns
531 posts in 3057 days
11-28-2013 01:19 AM
Can transtint be used to slightly alter the color of Arm-r-seal urethane? I have a table top that I had to make a repair to and the color on the center panel is a little off. It has a tinted lacquer undercoat with a clear urethane topcoat. I have already applied the first coat of urethane and want to know if I can use the second coat selectively as a toner to help blend in the repair better.
-- Beth, Oklahoma, Rambling Road Designs
View dahenley's profile
dahenley
136 posts in 1965 days
#1 posted 11-28-2013 01:46 AM
Why did you use arm-r-seal on finished furniture.
I always thought it was used to seal green lumber till its able to dry and the moisture content lowers so then you can make furniture with the wood
Also, its used on end grain.
-- David Henley
View pintodeluxe's profile
pintodeluxe
5544 posts in 2685 days
#2 posted 11-28-2013 01:54 AM
Transtint dyes, or universal colorants (available at paint stores) can be added to most any finish. I find it hard to avoid streaks or uneven colors when tinting a topcoat. I would refinish the top of a table, rather than mess with tinting. Tinting is especially problematic when brushing or wiping on a finish. Spraying it isn’t easy, but it has improved my success rate.
View tefinn's profile
tefinn
1222 posts in 2308 days
#3 posted 11-28-2013 01:58 AM
Beth – You can add Transtint to the Arm-R-Seal. It may not give the desired results, but it could help.
dahenley – GF Arm-R-Seal is an oil urethane top coat used for finishing furniture. You’re thinking of Anchorseal.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View kdc68's profile
kdc68
2636 posts in 2148 days
#4 posted 11-28-2013 02:13 AM
I’ve only used Transtint in shellac and distilled water on bare wood, so no experience tinting a topcoat….but here’s a helpful link below
http://www.joewoodworker.com/transtints.htm
-- Measure "at least" twice and cut once
4827 posts in 2365 days
#5 posted 11-28-2013 01:55 PM
It can be done successfully. Jeff Jewitt recommends you add to Transtint to a little MEK or acetone, then ad that to the Arm R seal. Take a glance at this thread another forum to see what a little more info.
rrdesigns
#6 posted 11-28-2013 09:08 PM
Thanks for all the suggestions. I have attempted a tinted coat of shellac between the layers of arm-r-seal. Tomorrow will tell me whether or not I was successful when it is has had time to dry over night.
