Moxon Vise jaw material
Forum topic by Sirgreggins posted 11-27-2013 03:12 PM 1778 views 0 times favorited 6 replies Add to Favorites Watch
View Sirgreggins's profile
Sirgreggins
299 posts in 2409 days
11-27-2013 03:12 PM
I’m going to make a moxon vise soon, but i was wondering what to make it out of. Could i laminate a couples pieces of 3/4” ply together, or should i got with 8/4 stock?
View nwbusa's profile
nwbusa
1021 posts in 2460 days
#1 posted 11-27-2013 07:59 PM
The ones I’ve seen have used hardwood jaws, but no reason I can think of that a good quality plywood wouldn’t work. You’d want it thick enough to prevent deflection under pressure.
-- John, BC, Canada
View richardwootton's profile
richardwootton
1701 posts in 2129 days
#2 posted 11-27-2013 09:20 PM
I’m on the same page as John. I would personally want one from solid hardwood, but that’s mainly for aesthetic reasons.
-- Richard, Hot Springs, Ar -- Galoot In Training
View 12strings's profile
12strings
434 posts in 2558 days
#3 posted 11-27-2013 10:17 PM
Hard wood will give you the most strength where you need it…across the span between the 2 screws. Hard maple is the obvious choice, but a softer wood would work with added thickness.
I don’t think the verticle grain in plywood has any real advantage in this application.
-- I'm strictly hand-tool only...unless the power tool is faster and easier!
View JayT's profile
JayT
5926 posts in 2385 days
#4 posted 11-27-2013 10:21 PM
The plywood won’t be strong enough to not flex. For one, it’s softwood and two, 1/2 the fibers will be running the wrong direction for the necessary strength. Either go with 8/4 hardwood or if you need to laminate, at least use a couple pieces of 4/4 hardwood.
edit: or +1 to 12 strings
nwbusa
#5 posted 11-29-2013 03:03 AM
Not all plywood is softwood. Baltic birch is very strong and two or even three thicknesses laminated over the length of a Moxon vise would be plenty stiff enough. That said, I agree that hardwood is the better choice, if only because you wouldn’t have to screw around with a glue-up.
-- John, BC, Canada
Sirgreggins
#6 posted 12-02-2013 03:01 PM
I’ll have to look around for some cheap 8/4 hardwood then. Thanks guys
