Using a wixey and a miter saw
« back to Joinery forum
Forum topic by Farley posted 11-26-2013 07:12 PM 1336 views 0 times favorited 7 replies Add to Favorites Watch
View Farley's profile
Farley
15 posts in 1617 days
11-26-2013 07:12 PM
I want to get better angle cuts with my power miter saw.
I have a wixey but can,t figure out how to adjust the arm to a specific degree.
Say I want a 30 degree cut for segmenting. Using the scale on the base I could change the base to 30, but it,s not accurate enough.
I don,t want to till the blade, just rotate the table.
Talk down to me to make it simple.
Thanks
-- for cuts --- ducts tape works when you just can't stop.
7 replies so far
View danoaz's profile
danoaz
222 posts in 2136 days
#1 posted 11-26-2013 07:16 PM
Farley – what manufacturer of miter saw do you have? If people know that it will help a lot I think.
-- "Simplicity and repose are the qualities that measure the true value of any work of art." Frank LLoyd Wright
View Bill White's profile
Bill White
4904 posts in 3926 days
#2 posted 11-26-2013 07:40 PM
More info from you equals more info from us.
Bill
-- bill@magraphics.us
View CharlesA's profile
CharlesA
3312 posts in 1764 days
#3 posted 11-26-2013 07:45 PM
If you’re speaking of the Wixey magnetic digital gauge, I don’t think that works for rotation, only for tilt.
Farley
#4 posted 11-26-2013 07:55 PM
It a delta, but CharlesA might have the answer as to why the Wixey doesn’t produce the results I thought i would get.
I just want to get a more precise cut other than the gauge on the base, because we know that’s not alway perfect.
Farley
#5 posted 11-26-2013 10:35 PM
I just went old school.
made sure the saw cut at 90 degree
then put a simple compass, like the ones in school.
it may not be perfect, but I can then sand it flat using two halves once some joints are glued up.
View hobby1's profile
hobby1
335 posts in 2264 days
#6 posted 11-26-2013 11:27 PM
one way to get a fairly accurate, angle setup, I use my speedsquare to draw an angle line on a piece of scrap board, then set my bevel guage to it, and transfer the guage setting to my miter saw, a few trial and error cuts, and it finally gets dialed in.
View jtm's profile
jtm
230 posts in 1602 days
#7 posted 12-03-2013 04:18 AM
If you are trying to use the wixey for the miter function of the saw (as in grab the front handle and move it left or right), it will not work.
However, if you are trying to use the bevel function of the saw (the back knob on the saw), then you’re in luck.
I know this because I researched it for that exact reason (I bought one anyway, though).
