rockwell beaver lathe spindle adapters
« back to Woodturning forum
Forum topic by praspekt posted 11-26-2013 07:31 AM 6379 views 0 times favorited 21 replies Add to Favorites Watch
View praspekt's profile
praspekt
18 posts in 1978 days
11-26-2013 07:31 AM
all of my chucks are 1” 8 tpi, and i just found an old rockwell beaver that has outboard turning, though the outboard spindle is 3/4” 16 tpi, and the inboard spindle is 7/8” 14 tpi. does anyone happen to know were i can find decent quality spindle adapters? the outboard spindle is left threaded, and the inboard standard.
thanks! i can’t wait to play with the lathe, it’s a lot bigger then my other lathe..
21 replies so far
View Woodknack's profile (online now)
Woodknack
12243 posts in 2466 days
#1 posted 11-26-2013 08:03 AM
View Wildwood's profile
Wildwood
2378 posts in 2220 days
#2 posted 11-26-2013 12:38 PM
Do not know what brand chucks you have, better contact manufacturers, for thread adapters/inserts.
Even if do not have thread sizes you need can provide dimension/tolerances needed to have one made that will fit your chuck. Big concern is run out, too much not good!
While might not have a problem finding ¾” x 16 TPI, for wood lathes not sure about 7/8” x 14 TPI.
Good luck!
-- Bill
View bondogaposis's profile
bondogaposis
4899 posts in 2437 days
#3 posted 11-26-2013 01:12 PM
Penn State has spindle adapters here.
-- Bondo Gaposis
praspekt
#4 posted 11-26-2013 08:17 PM
thanks for the info!!
View Brian Myers's profile
Brian Myers
17 posts in 1812 days
#5 posted 12-04-2013 03:21 AM
When you run into odd lathe spindle sizes , Oneway is the place to go. Good luck finding a straight forward spindle adapter for 7/8×14 but all 3 of Oneway’s chucks do have adapters for that size. They do make a very nice chuck. Your other choice would be to find a machinist to make a 7/8×14 to 1×8 . See if you can find a retired one that still has a lathe. That seems to be the cheapest way to go for custom work.
-- Wood worker , wood turner, wood artist , don't they all mean the same thing as wood hoarder?
praspekt
#6 posted 12-04-2013 05:12 AM
http://bestwoodtools.stores.yahoo.net/prstspadwith.html
i found this guy.. i already have an axminster chuck that i’m happy with, and would much rather not invest in another chuck. though, one thing that i did think about though, was that on this lathe there is LH threading on the outboard side, so do i need to get another chuck that has LH threading? i’m not really looking forward to having to retrain my hands with the rotation of the bowl going opposite..
are there modifications that could be made to the outboard spindle for it to spin counter clockwise?
Woodknack
#7 posted 12-04-2013 06:35 AM
If it’s anything like my Craftsman lathe then yes you’ll need a LH adapter for the outboard spindle.
praspekt
#8 posted 12-04-2013 08:23 AM
what do you mean? an adapter so it can rotate the other way?
Wildwood
#9 posted 12-04-2013 11:23 AM
Special thread sizes NOT SHOWN BELOW are available on request. Please call us at 931-788-0429 for a quotation or email us at sales@bestwoodtools.com .
Why not just email best tools, and see if can make one for you.
-- Bill
Woodknack
#10 posted 12-04-2013 08:18 PM
You need a motor that reverses to spin it the other way and you’ll need a LH thread adapter for your chuck. And if you reverse the lathe then make sure the chuck uses a set screw or it will spin off. Or just get yourself a 3/4-16 LH tap and make a sanding/sharpening disc for the outboard spindle.
praspekt
#11 posted 12-04-2013 10:25 PM
i can always wire a switch for opposite direction. so should i get an adapter with a female 3/4-16 LH with a set screw, and a male end of 1”-8 RH? i guess i can drill a hole where the set screw will be to hold it securely and not mess up the thread too much.
Woodknack
#12 posted 12-05-2013 05:21 AM
I’m curious how this will turn out. The good news is that Oneway sells all the adapters so you might want to chat with them a bit.
Brian Myers
#13 posted 12-06-2013 02:42 PM
Why would you need to retrain yourself ? Your position at the lathe changes but it’s still all done the same as if you were standing in the normal position. Provided you are standing out of the line of fire, the blank with still be rotating toward you, the difference is you won’t have the bed of the lathe in the way. You will effectively be standing behind and on the opposite side of the lathe to use the outboard position.
View Arminius's profile
Arminius
304 posts in 3889 days
#14 posted 12-06-2013 04:15 PM
I would suggest you check out the Canadian Woodworking forum on turning for info on the Beaver lathes. Lots of threads on them – I have a pre-Rockwell (Callander Foundry) model.
praspekt
#15 posted 12-07-2013 06:01 PM
i called up oneway the other day, and the guy told me to not go the LH threaded, with a lock screw, and not switch the rotation.
Brian.. the retraining comes from working from the opposite side of the piece. on the inboard it rotates counter clockwise, and when working a bowl i work from left towards the center, on the outboard side, with the LH threading, the rotation is going clockwise, so i’ll be working a bowl from right to center.. for some reason it just intimidates me.. though i’m going to be getting a LH threaded face plate soon, and start playing. i’m just kinda new to turning, only about a year, still learning..
how large or a bowl could be turned on a rockwell lathe?? is 20” a bit ambitious?
arminius, thanks for the info, i’ll check it out.
