Cabinet Design Help
Forum topic by Timberwerkz posted 12-08-2008 06:40 PM 1117 views 0 times favorited 8 replies Add to Favorites Watch
View Timberwerkz's profile
Timberwerkz
20 posts in 3705 days
12-08-2008 06:40 PM
I am building cabinets for a kitchen the problem I have is with an upper corner cabinet. I make my cabinets 14” deep so you can put a 12” platter on the inside . My corner cabinet can only come 21” inches from the corner because that is where the wall opens up for a bar. I did a full scale layout on plywood and the door is really small, if you put it at a 45. I also did in an “L” shape and things still seem small. My customer wants a lazy susan in the cabinet. So I feel a little restricted in what I can do. Whatever suggestions can be had would be extremely helpful.
Thanks Chris
8 replies so far
dennis mitchell
3994 posts in 4553 days
#1 posted 12-08-2008 06:50 PM
So is the space for the cabinet 21 deep X 21 wide? Full overlay doors? euro or face frame? Is one side of cabinet a finished end?
Timberwerkz
#2 posted 12-08-2008 06:53 PM
2” Face frame. I have 21” on one side I could make the other side as big as I wanted, I just that would make it hard to find a lazy susan that would fit.
Chris
dennis mitchell
#3 posted 12-08-2008 06:57 PM
So you could have a bifold door. Inside the cabinet have shelves on one side and the standard lazy susan on the other.
View johnpoole's profile
johnpoole
74 posts in 3705 days
#4 posted 12-08-2008 08:13 PM
i added a corner overhead with a 90 degree door.. looks like two small raised panel doors with the faceframe right angled between them.. but it’s one door with a lazy susan behind it. i built the ls using glass marbles for bearings… just routed a channel for the marbles on both the stationary bottom and the round shelf. the marbles can’t escape and they are not seen.. and it’s been working for 20+ years.
might not be the right solution for you. i have a hard time without something to look at.. i seldom work from plans, usually the loml finds a picture in a magizine then shows me the spot it needs to fit in
-- it's not a sickness, i can stop buying tools anytime i want
Timberwerkz
#5 posted 12-08-2008 09:22 PM
http://i370.photobucket.com/albums/oo150/Timberwerkz/Cornerhell-1.jpg
I think I did this rite. Here is a drawing of the wall. The space between cabinets and end of walls is for casing. My problems is it makes for a really small door
Timberwerkz
#6 posted 12-08-2008 09:45 PM
OK did it wrong. Followed direction in the embed photos but don’t know what went wrong. Used photobucket and never saw the little yellow box that said copied. Someone please help
Thanks
Chris
dennis mitchell
#7 posted 12-09-2008 01:17 AM
...the door dosn’t even need to be a bifold. You could build it ridgid with the hinged side being the short side and the larger door to the left.
View Thos. Angle's profile
Thos. Angle
4444 posts in 4201 days
#8 posted 12-09-2008 04:02 PM
On bentlyj’s drawing you could also use the 10” cabinet as open shelves. We have one of those and my wife loves it for display. Looks like a good solution. I usually design from the corner out.
