Planing question.
Forum topic by Mark posted 11-25-2013 08:48 PM 865 views 0 times favorited 7 replies Add to Favorites Watch
View Mark's profile
Mark
916 posts in 1997 days
11-25-2013 08:48 PM
Afternoon all. I need to re-saw some 3/4×6 walnut into 3/8” wide strips ( 3/8×6” ). I will have to run them through my thickness planer to clean up the re-saw and to trim them down to 1/4”. As they say not to try any thing that thin in the planer I guess I need to use a sled. The question is how do I hold the walnut strips on the sled? I thought about putting a stop on the end of the sled…Is that what you would recommend? Thank you. Mark
-- Mark
7 replies so far
View TaybulSawz's profile
TaybulSawz
156 posts in 1705 days
#1 posted 11-25-2013 08:54 PM
Put a 11” wide by 3/4” thick piece of MDF on top of your planer bed. This will allow you to plane to 1/4” Make sure your Blades are SUPER Sharp!!
-- Still got all my Fingers!!!
View shampeon's profile
shampeon
1775 posts in 2206 days
#2 posted 11-25-2013 08:57 PM
Double sided tape works well for this.
4998 posts in 2516 days
#3 posted 11-25-2013 09:09 PM
I do it the way taybulsawz suggested, but I use melamine (much more slick).
View Texcaster's profile
Texcaster
1285 posts in 1696 days
#4 posted 11-25-2013 09:19 PM
I have a powerful 3ph planer. I don’t need a stop or tape, the feed rollers are strong enough to send both pieces thru as a unit. Most timbers I can take down to 3mm. with vapor cuts the thinner I go. Too heavy and it comes out the other side as chips. I make veneers to laminate body rests for elec double basses.
-- Mama calls me Texcaster but my real name is Mr. Earl.
View Dan Lyke's profile
Dan Lyke
1520 posts in 4148 days
#5 posted 11-25-2013 11:48 PM
I have run 1/8”x3/4” maple through my planer (DeWalt 735, it goes to 1/8”), it bounced on the tail end and sniped, but the rest came through okay. I have also had bad luck trying to run other thin stock through, so your mileage definitely will vary.
For holding it down to a sled: Exterior double-sided carpet tape is your best friend. That stuff finds a gazillion uses in the shop.
View pintodeluxe's profile
pintodeluxe
5702 posts in 2836 days
#6 posted 11-25-2013 11:50 PM
I see surface quality decrease at 1/8” thick, but you shouldn’t have any trouble planing to 1/4” thick.
No need for sleds or jigs. Just make the pieces a little longer than needed in case it snipes.
View Mark's profile
Mark
#7 posted 11-26-2013 01:01 AM
Thank you gentlemen.
-- Mark
