Padauk bleeding. Everything is pink!
Forum topic by TaleSspin posted 11-25-2013 06:15 PM 2308 views 1 time favorited 9 replies Add to Favorites Watch
View TaleSspin's profile
TaleSspin
1 post in 1554 days
11-25-2013 06:15 PM
I’ve made a table top with alternating strips of padauk and maple. May have been a bad idea.
I’ve had to scrap it to finish instead of sand so the maple doesn’t turn pink, but I am now afraid that if I apply any liquid finish it will bleed the red color into the finish and turn the maple pink, especially if worked in.
Have any of you experience with padauk combined with other woods and/or finishing padauk?
9 replies so far
13594 posts in 3249 days
#1 posted 11-25-2013 06:20 PM
i learned to wash it first with lacquer thinner
not rubbed hard with the grain
and with a new spot on the rag
for each swipe
after blowing off good with the air hose
seal good before light between coat sanding
(220 grit)
View bondogaposis's profile (online now)
bondogaposis
4611 posts in 2259 days
#2 posted 11-25-2013 06:24 PM
I’ve not had a problem doing this. I think mostly the problem comes sanding and the dust coloring the maple. Once the sanding is over and cleaned up there shouldn’t be any bleed over. What type of finish are you going to apply? If you are planning on an oil base finish, wipe a part of the under side w/ mineral spirits. If it doesn’t bleed you are good to go. If it does bleed then consider sealing it w/ shellac or use a water base finish.
-- Bondo Gaposis
View redryder's profile
redryder
2393 posts in 3010 days
#3 posted 11-25-2013 08:18 PM
It’s not bleeding from one wood to the other. As stated above, just sanding dust from the Padauk. I use mineral spirits and a rag the same as patron mentioned. I haven’t used lacquer thinner but it could be just as good. Many of my picture frames have padauk in them and as Patron stated, go with the grain when cleaning. After cleaning as good as possible a sealer will seal the deal. A large surface like a table may be problematic but elbow grease and lesson learned…......................
-- mike...............
View BigYin's profile
BigYin
406 posts in 2324 days
#4 posted 11-25-2013 08:23 PM
use cabinet scraper not sandpaper if using padauk with another wood
-- ... Never Apologise For Being Right ...
16272 posts in 4127 days
#5 posted 11-25-2013 08:46 PM
+1 to what David (patron) said!
View ardoc's profile
ardoc
13 posts in 1556 days
#6 posted 11-26-2013 01:39 AM
I just made 3 Dough boards in the last year for family, the boards main body is curly maple, with paduak at either end, sanding caused the dust to go on maple but cleaned up fine with a tack cloth and clean rag, finished it off with butcher clock oil, they get a lot of use and this far everything looks justa as good as when I made them.
View Woodknack's profile
Woodknack
11137 posts in 2288 days
#7 posted 11-26-2013 08:07 AM
Lacquer thinner will cause the red to bleed. You can make a red dye with lacquer thinner and paduak chips. I’ve had better luck spraying, wiping finishes turn the maple pink. Whatever you do, test it on the underside first.
-- http://thewoodknack.blogspot.com/
View Tennessee's profile
Tennessee
2755 posts in 2423 days
#8 posted 11-26-2013 12:44 PM
+2 to what patron said. I’ve put paduak into many of my guitars, and this always happens, and it is always corrected with a simple lacquer thinner wipe down. Once the dust is gone, you can proceed as normal.
Woodknack
#9 posted 11-26-2013 09:08 PM
Well I can’t argue with your guy’s results so I’ll have to try this. In the past when I’ve touched padauk with any kind of thinner or wipe on finish it created an orange mess that stained the maple, that’s after I thought I cleaned off the sanding dust with a dry brush (no air in the shop). So do you just keep wiping and the tint goes away? Or are you saying to wipe it before glue up?
