jointer indfeed table stuck!
Forum topic by wildbuckalew posted 11-25-2013 04:45 PM 1140 views 0 times favorited 2 replies Add to Favorites Watch
View wildbuckalew's profile
1 post in 1575 days
11-25-2013 04:45 PM
Topic tags/keywords: jointer stuck maple question
hey, i joined the forum because i cant figure out why my jointer infeed table is stuck. its a delta 37-190. just picked up from a craiglist ad. it moved fine when the seller demo’d it for me. in order to transport it, i removed the jointer from the base. put it all back as it was and i was setting it up and testing it out. the only “bad” thing i did was try to do a full 1/8” cut on a 2” chunk of hard maple and bogged the motor down to a stall then it kicked back on, and came up to speed. any ideas?
2 replies so far
View chrisstef's profile
17248 posts in 2937 days
#1 posted 11-25-2013 04:54 PM
There should be some gib screws on the backside of the jointer. Try and loosen them up with a hex key / allen key and adjust your table once theyre loosened. They should press against the dovetailed ways. Once you get your infeed all set to the proper height tighten those gib screws back down. They may or may not throw the table a bit out of whack so you’ve gotta play with them a little bit.
View TaybulSawz's profile
156 posts in 1613 days
#2 posted 11-25-2013 05:20 PM
Here’s the Manual for it.
It has Pics and details on how to do all the adjustments to the infeed table starting on Page 15.
-- Still got all my Fingers!!!
