miniwax wipe on poly
Forum topic by steveh0203 posted 11-25-2013 04:45 PM 910 views 0 times favorited 4 replies Add to Favorites Watch
View steveh0203's profile
steveh0203
1 post in 1551 days
11-25-2013 04:45 PM
I am trying to refinish some handgun grips. I had some Miniwax wipe on poly that I have had for a couple of years. I put some on my grips and it looked fine. After it had time to dry and I checked it out. There were spots that looked like to poly just soaked up in the wood and left a dull looking spot. Other places there were a slight shine. I tried shaking the poly good. Could the poly be bad causing this problem.
16272 posts in 4125 days
#1 posted 11-25-2013 04:53 PM
This is pretty normal, in my experience. Because wipe-on poly is so thin, it readily soaks in to the more porous areas of the wood. The solution is to keep adding coats until the finish is even.
View coachmancuso's profile
coachmancuso
259 posts in 1838 days
#2 posted 11-25-2013 05:07 PM
It takes multiple coats to get the finish you want. When I use that wipe on poly it never takes in 1 coat with me it takes 5 coats to get the finish nice and even
-- Coach Mancuso
View GeneR's profile
GeneR
151 posts in 1845 days
#3 posted 11-25-2013 05:23 PM
one other option is to use shellac over your stain or oil as your first coat of clear to seal the wood, lightly sand it then use the poly over top as shellac can be used under all finishes.
-- Failure is always an option. :-)
View rum's profile
rum
148 posts in 2492 days
#4 posted 11-25-2013 06:24 PM
I usually start liking the look of wipe on poly after somewhere around 5-6 coats.
Sand back the first coat with 320.
Apply two more thin coats
Sand back with 400+
Apply a super thin coat
see how it looks
maybe apply another super thin coat
Let cure for a week
buff with a crushed up brown paper bag
top coat with carnuba and buff with a soft cloth
Brilliance
