how much sanding must one do?
Forum topic by Sawdust2012 posted 11-24-2013 10:40 PM 898 views 0 times favorited 2 replies Add to Favorites Watch
View Sawdust2012's profile
Sawdust2012
151 posts in 1950 days
11-24-2013 10:40 PM
Good Evening.
I am trying to make some bottle stoppers which I finish with danish oil, then buff with a 3 wheel system. It seems there is no limit to the sanding. I seem to spend geological amounts of time with 230 grit paper before moving to 600. If there is the slightest flaw in the surface it is magnified when buffing. Is this just the nature of the beast or am I doing something wrong?
2 replies so far
View Loren's profile
10477 posts in 3886 days
#1 posted 11-24-2013 11:55 PM
End grain is the trickiest to sand to a polish. You may want to
experiment with grain fillers. Tool marks on end grain of turned
work can be particularly troublesome to sand.
View bondogaposis's profile
bondogaposis
5151 posts in 2589 days
#2 posted 11-24-2013 11:59 PM
Start with a coarser grit to hog off all of the flaws, then and only then, start dropping grit sizes. I always start with 100 grit or coarser. Once you get all of the flaws out the finer grits go pretty fast.
-- Bondo Gaposis
