How long a Band Saw Blade should last?
Forum topic by b2rtch posted 11-23-2013 11:16 PM 5894 views 0 times favorited 12 replies Add to Favorites Watch
View b2rtch's profile
b2rtch
4847 posts in 2958 days
11-23-2013 11:16 PM
Topic tags/keywords: question bandsaw
In the past I bought Wood Slicer band saw blades.
Now I buy my blades local to give my business this Christian small business.
The blades that I buy there look identical to Wood Slicer blades and initially they are extremely sharp, may be too sharp as I damaged several of them on the very first cut as they grab so much.
I use 1/2×3 TPI on my 14 band-saw to resaw these 6×12 beams that I have.
I cut may be 100 linear feet and they blade noticeably dulled out.
Is this normal?
That does not seem normal to me.
-- Bert
12 replies so far
View JustJoe's profile
JustJoe
1554 posts in 1948 days
#1 posted 11-23-2013 11:19 PM
I use woodslicer, that’s not normal for them. But maybe it’s the wood. Are the beams treated, or greener than KD lumber?
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
b2rtch
#2 posted 11-23-2013 11:20 PM
The beam are beautiful straight grain fir but old and dry.
-- Bert
View hydro's profile
hydro
208 posts in 1661 days
#3 posted 11-23-2013 11:27 PM
Band saw blades will cut a long time as long as you do not hit something hard. I suspect the beams you are cutting have dirt somewhere that you are cutting through, dulling the blades. I use Lenox Woodmaster blades and they have performed very well, beyond expectations for me. They may be a little thick for a 14” saw however.
-- Minnesota Woodworkers Guild, Past President, Lifetime member.
View Dallas's profile
Dallas
3599 posts in 2397 days
#4 posted 11-23-2013 11:39 PM
Bert, I have cutting old white oak on my 12” saw for the last year with the same Olsen blade.
The cuts are 6” x 53”.
This blade is starting to slow down a bit, but works good for most of my other needs.
I think I have put through about 1200-1500 cuts so far.
I may keep it and try my hand at sharpening.
Not an expensive blade, only about $13 each. 1/2” by 3 tpi raker tooth x 80 1/2”
b2rtch
#5 posted 11-23-2013 11:47 PM
I going to have a talk with guy I buy the blades from and ask him his opinion
-- Bert
View Loren's profile
9986 posts in 3557 days
#6 posted 11-24-2013 12:06 AM
I have not found any carbon steel band saw blade to stay
sharp very long cutting wood, Woodslicers included.
This is why I now buy coil stock and solder my own blades.
The savings is a lot.
View pintodeluxe's profile
pintodeluxe
5569 posts in 2723 days
#7 posted 11-24-2013 12:10 AM
I have found when resawing that my bandsaw blades don’t last very long at all. Also, when resawing I need the blade to be sharp to make a quality cut.
Whereas cutting arches in 3/4” stock even a dull blade can handle okay.
I think it is just a limitation of plain steel blades. For some reason carbide tipped blades are still expensive for bandsaws, yet they are more affordable for tablesaws and router bits.
View RogerInColorado's profile
RogerInColorado
321 posts in 1864 days
#8 posted 11-24-2013 12:12 AM
Bert, if I was in your shoes I’d buy another woodslicer and see how it preformed in this same stock before I passed judgment. I like buying local, too, but cost to performance ratio can’t be severely out of whack. In this case, all may be kosher but you don’t know until you compare a woodslicer to your new blade.
hydro
#9 posted 11-24-2013 12:14 AM
Dallas,- I sharpen my blades once, maybe twice before discarding. I have a 1/4” white wheel shaped to the gullet profile (using a dressing stick) and just touch off the teeth by hand. It works very well considering the lack of precision. The wheel is just an old surface grinder wheel from a surplus store that I re-worked to shape. Give it a try on a blade that has become dull. All you have to lose is a few bucks for a wheel and an old blade.
Loren, There is nothing special about the Wood Slicer blades. They are just a well made, thin (.025”?) blade that has been well marketed. Now if there were a 1/2” wide M42 HSS blade in 3/4 variable TPI and .025” thick, that would be the ticket!
View Loco's profile
Loco
210 posts in 1659 days
#10 posted 11-24-2013 12:18 AM
Bandsaw blades are irrelevant-....consumables. They also shouldn’t be used on useless crap.Waste of money/time.
I get a chuckle out of some dork tossing a sheet of Chinese plywood through a $1200 table saw bleating about doing “wood work”.
-- What day is it ? No matter. Ummmm What month is it ? No moron. I paid for a 2 x 6. That means Two inches by six inches. I want the rest of my wood.
Dallas
#11 posted 11-24-2013 12:54 AM
Hydro, I use to sharpen my wood mizer blades at night. I wasn’t fond of it but I set up a cool little juig for myself that made it much easier.
The blades lasted much longer and would stay sharp for a longer time.
I may build a sharpening jig like that for my small band saw blades.
b2rtch
#12 posted 11-24-2013 11:21 AM
I ended up ripping these beams on my table saw, using a Irwin 50 teeth combination blade (when I have several 32 teeth Freud ripping blades) which cut these beams like butter.
-- Bert
