Making A Rabbet in 1/2' Baltic Birch Plywood Best Practice
« back to Joinery forum
Forum topic by Shopguy posted 11-23-2013 03:25 AM 1134 views 0 times favorited 6 replies Add to Favorites Watch
View Shopguy's profile
Shopguy
12 posts in 1973 days
11-23-2013 03:25 AM
I am building a sanding downdraft box from 1/2” Baltic birch plywood and need to make 1/4”W x 1/2”H rabbets in the box sides to accept the bottom panel.
I have both a stackable and wobble dado blade for the table saw and a router table with both upspiral and regular straight bits of various sizes.
As I was planning the cut, I asked myself should I stand the side on edge and make rabbet or put the side on the face and make the rabbet.
What is the best practice to make this rabbet that would minimize tear out? Should the router bit or saw blade be parallel or perpendicular to the plywood plys when making the cut?
Thanks,
Roger
View RockyTopScott's profile
RockyTopScott
1186 posts in 3350 days
#1 posted 11-23-2013 03:35 AM
On the face. Use some tape and a score line to minimize tear out
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
View ajosephg's profile
ajosephg
1880 posts in 3433 days
#2 posted 11-23-2013 03:42 AM
+1 on Rocky
If you use a sharp up cut router bit you shouldn’t have any tear out, at least I never do. Direction makes no difference, but if you’re nervous go parallel with the face grain.
-- Joe
View MT_Stringer's profile
MT_Stringer
3134 posts in 3103 days
#3 posted 11-23-2013 03:47 AM
Face down.
View jumbojack's profile
jumbojack
1673 posts in 2496 days
#4 posted 11-23-2013 03:50 AM
Dig a DEEP hole like 5’ or better. Throw a sack of fence post concrete in then the wobble dado blade followed by another sack of concrete. Soak with a hose and fill in with remaining dirt.
That said I never have a problem running rabbets with a sharp dado stack.
Shopguy
#5 posted 11-25-2013 03:56 AM
Thanks to all that provided great ideas. I set up a 5/8” diameter straight carbide router bit in my router table that has an Incra/Jessem Router Lift II, set the fence for a 1/2” width cut and 1/4” bit height and routed a clean rabbet in the Baltic birch plywood. Used a backer board to eliminate tear out. Joints are perfect.
Roger
View DangerDoug's profile
DangerDoug
72 posts in 1519 days
#6 posted 11-25-2013 10:38 AM
I found a use for a wobble dado they other day, they do cut 1/4” or less. Stack dadoes won’t do that; not mine anyway.
