disappointed in Woodcrafts seam ripper kit
« back to Woodturning forum
Forum topic by jeff posted 11-23-2013 02:45 AM 3013 views 0 times favorited 10 replies Add to Favorites Watch
View jeff's profile
jeff
1120 posts in 3662 days
11-23-2013 02:45 AM
turned a seam ripper kit this evening and the rubber O rings will not fit into the brass tube…tried enlarging the inner diameter of the brass tube but have had no luck in getting a good fit and a few of the rubber O rings are now worn…anybody tried this kit and have you run into this same problem?...will probably take the kit back to Woodcraft for a refund…
-- Jeff,Tucson,Az.
10 replies so far
View cabmaker's profile
cabmaker
1740 posts in 3006 days
#1 posted 11-23-2013 03:36 AM
Jeff,
You might try warming the brass with heat gun, hair dryer or whatever you have there and put the o ring in the freezer for five minutes then try again.
How close of fit are we talking here
O rings of many varying sizes are readily available
JB
View jeff's profile
jeff
#2 posted 11-23-2013 03:49 AM
JB…you really can’t adance the seam ripper into the tube…
-- Jeff,Tucson,Az.
View waho6o9's profile
waho6o9
8516 posts in 2774 days
#3 posted 11-23-2013 04:23 AM
“The O-rings when installed on the blade holder make it to large to fit inside the brass tube. I have found that by turning the blade holder on my lathe in a chuck fitted with pin jaws I can sand the grove and reduce the diameter enough that the O-rings will fit inside the brass tubes. It take a few attempts to get the fit right. I also chamfer the brass tube slightly. I’ve also noticed while test fitting the blade holder (with the O-rings installed) that twisting the blade holder while pushing it in the tube works the best. Often no further modification is required. – See more at: http://www.woodcraft.com/product/2084945/38850/seam-ripper-kit-gold.aspx#ProdInformationTab
Others have had problems as well. Check the reviews and maybe something will work for you.
HTH
View jeff's profile
jeff
#4 posted 11-23-2013 08:11 AM
thx waho609 i will do so…
-- Jeff,Tucson,Az.
View Wildwood's profile
Wildwood
2469 posts in 2332 days
#5 posted 11-23-2013 05:46 PM
At one time Woodcraft was a reseller for Berea Hardwoods products. Not sure if that is still true. Berea instruction easier to follow. Berea definitely tells you to increase tube size with sand paper, oil & wipe off o-rings before installing. Just assume use a dowel & sandpaper to enlarge the tube.
http://www.bereahardwoods.com/pdf/Seam%20Ripper.pdf
-- Bill
117328 posts in 3774 days
#6 posted 11-23-2013 05:55 PM
This is new to me ,I didn’t even know woodcraft sold such a thing.
View jeff's profile
jeff
#7 posted 11-24-2013 12:33 AM
Thx Wildwood…I think I will try another seam ripper kit again…
-- Jeff,Tucson,Az.
View LordBTN's profile
LordBTN
6 posts in 1935 days
#8 posted 12-07-2013 11:15 PM
I just made on of these and it was a little tight but just a bit of mineral oil and worked like a champ
-- Where I work http://forthouston.com/
View jeff's profile
jeff
#9 posted 12-08-2013 03:57 AM
I have been meaning to update—-I went ahead and tried a new seam ripper kit…I used sand paper followed by fine steel wool like some suggested but had no luck…I then used a pair of small scissors to flair out one end of the brass tube a bit followed by fine steel wool and it worked very well…This will be a X-mass present and hopefully they will like so I can make more but I think I will try a drop of oil next time :)...thx everybody…
-- Jeff,Tucson,Az.
View NormG's profile
NormG
6283 posts in 3201 days
#10 posted 12-28-2013 09:08 PM
I made for xmas, what a bear to get adjusted for ease of removal and insertion.
-- Norman - I never never make a mistake, I just change the design.
